Door Mould Holes
hey guys
took advantage of the nice weather for once today and decided to remove the black door strips from the car, we used WD40 which worked excellent, however whilst removing the rear smaller strip bout 3 inches in i pulled it back and noticed a hole in the door where a locating pin on the mould sits into
decided to take it to body shop to have them removed and the holes patched, but he thinks they will look better colour coded
has anyone else found the holes behind the bump strips on their mk6?
Link to comment
imo i think the door looks cleaner and nicer without them but my gf likes them colour coded, having the boot handle done at the same time
Link to comment
already done them m8 did them last weekend, :)
albeit not professional like haha but they looks great, (2 primer, 2 colour and 2 laquer)
our next job was either the door strips of the boot handle,
going to work on the ignition illumination ring tomorrow
Link to comment
Sounds good mate. My not take pictures of your mods so far and start your own Modification Project thread that you can update as youdo more mods? We've just added new sections for discussing mods and for ongoing projects :) http://www.fordownersclub.com/forums/forum/88-ford-modifications-and-projects/
Link to comment
the thinner moulds (same shape across the door) i don't think are reusable, when we pulled our off today we weren't able to stick it back down,
what i would suggest is buy the ST door strips (different shape) these fit in the holes in door (behind the old strips) but will need some adhesive, that would of been the next option if weren't going to colour code the existing strips
Link to comment
How hard is it to remove the door strips without nackering them?
Thought about buying a primered set but if they're reusable then I might consider giving that a go.
Easy enough as long as you dont knacker the clips. I think in the focus theres metal strips through them aswel so youve got to ve careful not to bend them too much.
Link to comment
ahh excellent will get 1 going :)
Link to comment
Might still consider a new set primed and ready to spray then.
Should save a lot of rubbing down and the risk of ruining the original set and leaving the car stripless until I could get replacements.
There are some primed ones on eBay, not sure if they come with the clips though, they may only have tape on them.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
