bethxr2 Posted April 24, 2013 Share Posted April 24, 2013 i have a xr2i which is suffering from extreme jerking, its fine going fast but doesn't like going slow. on a little bit of throttle or deceleration it is terrible. changed plugs and leads, coil pack, air temp sensor coolant temp sensor. cleaned all breather pipes and idle control valve. its had a recent service. thinking maybe tps sensor or injectors? or maybe a fuelling problem. any help or ideas would be great thanks. don't know where to go next and can't just keep buying parts and hoping. thanks. Quote Link to comment Share on other sites More sharing options...
wase16ll Posted April 24, 2013 Share Posted April 24, 2013 give all earth connections in engine bay a good clean up/check, not just battery earths but all the connections. check wiring leading to coil pack, any bad connections there will cause this problem crank sensor/wiring might be breaking down. does this appear as an electrical/fuel type misfire..ie not a regular miss, or appear only running on 3 for eg, till you get the revs up if the latter, do a compression check Quote Link to comment Share on other sites More sharing options...
bethxr2 Posted April 25, 2013 Author Share Posted April 25, 2013 thanks for the reply, crank sensor has been changed aswell, i have done so much i forget. its defiantly not a regular miss and seems to me to be a fuelling problem. it drives lovely when you put your foot down just impossible to drive slow. will check all earth wires today now. doesn't feel like a cylinder is down, its just really frustrating trying to drive it in traffic. it just wants to be foot flat everywhere. Quote Link to comment Share on other sites More sharing options...
wase16ll Posted April 25, 2013 Share Posted April 25, 2013 check the fuel pump relay and wiring too then. any possibility of checking fuel pressure? Quote Link to comment Share on other sites More sharing options...
JasonEdwards Posted June 13, 2013 Share Posted June 13, 2013 Think you are on the right lines of the throttle position sensor. Don't think they were the most reliable and gave all sorts of driving problems. Think ford brought out modified gold plated terminals in the multiplug which would be cut off and re soldered on Quote Link to comment Share on other sites More sharing options...
Jordahair Posted June 20, 2022 Share Posted June 20, 2022 Hi guys what was the problem in the end? I have the same issue thanks Quote Link to comment Share on other sites More sharing options...
unofix Posted June 21, 2022 Share Posted June 21, 2022 You win June's award for asking a question on post that has been dead for 9 years, much like the car I shouldn't wonder. 🤣 1 Quote Link to comment Share on other sites More sharing options...
DaveT70 Posted June 21, 2022 Share Posted June 21, 2022 Yep, that car's returned to Asda's shelves at least three times by now 1 Quote Link to comment Share on other sites More sharing options...
