freeman119 Posted May 2, 2013 Share Posted May 2, 2013 Hi guys my car recently developed a squeak when turning after an inspection at the garage the mechanic said it was just a dry cv boot and sprayed it with wd40 to cure the squeak and for the most part the squeak has stopped but it does still do it at certain points. i just wondered if any one had any tips on better lubricating the boot to remove said squeak permanently,thanks regards, Rich Quote Link to comment Share on other sites More sharing options...
wase16ll Posted May 2, 2013 Share Posted May 2, 2013 if i understand this correctly, your talking about the outside of the boot....if so, you could stretch the boot slightly by removing the clip on the driveshaft, slide the back of the boot further back and resecure...will lessen the chance of the boot rubbing against itself on steering Quote Link to comment Share on other sites More sharing options...
freeman119 Posted May 2, 2013 Author Share Posted May 2, 2013 Thanks mate will try that Quote Link to comment Share on other sites More sharing options...
