UUilliam Posted May 20, 2013 Share Posted May 20, 2013 My radio controls have stopped working.The ok, and directional buttons don't work any more.anyone know how to fix this? Quote Link to comment Share on other sites More sharing options...
JoeZS19 Posted May 21, 2013 Share Posted May 21, 2013 Could try disconnecting the battery? which may/should reset the radio. the Mk7 fiesta's dont need a radio code when the battery is reconnected as the radio is registered to the car or something like that 2 Quote Link to comment Share on other sites More sharing options...
UUilliam Posted May 22, 2013 Author Share Posted May 22, 2013 Any other suggestions before disconnecting electronics (not wanting to incase it ends up causing more problems by resetting other stuff etc...)Was working perfect until a few days ago.Had my iPhone plugged in and brother went to select a song, then it stopped working.The keys still "work" like if you press one of the buttons, it shows the menu it should show, but when you try to navigate on the menu after that, nothing moves.I'll make a video of it and post up later,Worst comes to worst, I'll try the battery.got told to take it to the ford garage as it's under warranty, and that touching it would void warranty..I have a sub woofer installed (and high level adapter)So assume he had to remove it to get into it (but has been working fine after that was installed too) Quote Link to comment Share on other sites More sharing options...
JoeZS19 Posted May 22, 2013 Share Posted May 22, 2013 I know when my radio froze ( due to running the ford bluetooth sync update) i disconnected the battery, reconnected it and everything worked fine without any problems Quote Link to comment Share on other sites More sharing options...
ken Posted May 22, 2013 Share Posted May 22, 2013 Another vote for disconnecting the battery - helped with an issue i had a couple of years ago when the whole thing stopped working. Is it updated with the latest firmware? 1 Quote Link to comment Share on other sites More sharing options...
UUilliam Posted May 23, 2013 Author Share Posted May 23, 2013 I tried updating the firmware but nothing happened... even when following the instructions - maybe cause I don't have bluetooth? Quote Link to comment Share on other sites More sharing options...
iNath Posted May 23, 2013 Share Posted May 23, 2013 I tried updating the firmware but nothing happened... even when following the instructions - maybe cause I don't have bluetooth? Yes I believe the update is only for Bluetooth&USB stereos. Quote Link to comment Share on other sites More sharing options...
