S80 Posted June 20, 2013 Share Posted June 20, 2013 Hi Guys, First post, so "please be gentle with me" :) I've just acquired a 2005 55-reg 1.6 petrol Focus Mk2, and have tried replacing the air filter - only to find that all the airbox top cover fixing screws appear to have 'stripped' from the lower housing! I can understand one or two, maybe - but all of them?? So my question is - do the screws simply 'tap' into the lower half, or should there be 'inserts' in the lower half - into which the screws er, screw? If I need a new airbox, is there any difference between Mk1 an Mk2 varieties? Many thanks, David Quote Link to comment Share on other sites More sharing options...
btmaldon Posted June 20, 2013 Share Posted June 20, 2013 The screws just tap into the bottom half. They normally stay attached to the top half when you remove it. Not sure if your airbox is the same as the MK2.5 or not though as I haven't looked under the bonnet of a Mk2. Quote Link to comment Share on other sites More sharing options...
S80 Posted June 20, 2013 Author Share Posted June 20, 2013 Many thanks for that, Bruce - in which case it looks like a gorilla has serviced the car in the past I'll try inserting a bit of 'padding' into the holes to try and give the screws something to bite into - if that fails then I guess it's a new box :( Cheers Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted June 20, 2013 Share Posted June 20, 2013 The boxes are different beyeeen MKs and also engine sizes/fuel types. Quote Link to comment Share on other sites More sharing options...
DanGersFord Posted June 22, 2013 Share Posted June 22, 2013 Moved to focus section Quote Link to comment Share on other sites More sharing options...
artscot79 Posted June 22, 2013 Share Posted June 22, 2013 use a flat head screwdriver to lever the top part up as you undo the screws or as youre loosening them with the torque driver pull up on it a little the are screws into plastic threads doesnt take much to strip them Quote Link to comment Share on other sites More sharing options...
