E C U
Karoline
Hi, can some one tell me where the ecu is in new edition 2005 focus, I've been told to different places, behind the glove box and next to the battery. Thanks caroline
Ok, I have found it it is beside the battery, but now I'm having trouble removing it from the loom connectors, there is a 10 mm bolt with no obvious way of how to undo it as its domed, Caroline
  • 4 weeks later...
Karoline, I found mine on the 2006 model (same as yours) at the front of the left wheel well. It's a real faff. Best to remove the wheel first. Then unscrew all of the screws holding the plastic splash guard and remove it completely. You'll see an odd shaped black plastic box standing vertically. Unscrew the torx bolts (4, maybe 6) and remove the cover to get to the ECU. Mark
