Trigger1984 Posted July 4, 2013 Share Posted July 4, 2013 Can anyone help i'm trying to find out if this ford sat nav system is run by a disc or sd this in my 2009 focus Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 5, 2013 Share Posted July 5, 2013 Pretty sure it's SD card. Quote Link to comment Share on other sites More sharing options...
Postie123 Posted July 5, 2013 Share Posted July 5, 2013 It is an SD card, it's to the left of the screen. To get it out just push it in and it will pop out but make sure the stereo is off. It should be blue or yellow, yellow being newer version compared to the blue. Quote Link to comment Share on other sites More sharing options...
johnson293 Posted July 5, 2013 Share Posted July 5, 2013 Yeah, I have the same unit - the maps are all on the SD card, as I tried it when I bought it and there were no maps/navigation available until I put the SD card in. Incidentally, does anyone know if its possible to get the maps updated, and how much it costs? Do they have to be maps from Ford, or are other sat nav maps (tomtom, Garmin, etc) map packs compatible? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 5, 2013 Share Posted July 5, 2013 The SD cards from Ford cost an arm and a leg. There are usually some available on eBay, just check that they're originals not copies. Afaik the navs aren't compatible with other map packs. Quote Link to comment Share on other sites More sharing options...
Preee Posted July 5, 2013 Share Posted July 5, 2013 Since they changed to the new Focus in 2011 no new maps have been eleased as far as i am aware , if your after the manual for that satnav unit , then see a link in my signature below for a download. Even with out the card you should stll be able to get basic postion information on the screen but no routing. Quote Link to comment Share on other sites More sharing options...
johnson293 Posted July 5, 2013 Share Posted July 5, 2013 Checked this evening, and my SD card says it is the 2009 version of the maps. Had a look on eBay, and most of the recent SD map cards for it seem to be about £40 upwards. I'll probably just stick with the ones I've got, for the amount I use it - but if it had been cheaper, I'd upgrade them. Cheers fro that link Preee, I had found the manual online already, as the car didn't come with that manual. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 6, 2013 Share Posted July 6, 2013 £40 is cheap :). Try asking Ford what they charge for them. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted July 6, 2013 Share Posted July 6, 2013 Last time I asked, Ford wanted about 200-250 for an SD Card. Quote Link to comment Share on other sites More sharing options...
Trigger1984 Posted July 6, 2013 Author Share Posted July 6, 2013 so the sd card bought from ford are either yellow or blue Quote Link to comment Share on other sites More sharing options...
Jordirob Posted October 3, 2015 Share Posted October 3, 2015 Just been quoted £78 for an SD card as my 2010 Zetec has this exact same system but no SD card and the dealership has taken 2 weeks to get nowhere. There are a host of them on eBay but which is the one to get. They all seem to suggest checking part number but my manual is generic and hasn't got a part number listed. Si I'm stuck with lots of cards to choose and unable to make a purchase as I don't know which one to get. Suggestions ? Quote Link to comment Share on other sites More sharing options...
Preee Posted October 3, 2015 Share Posted October 3, 2015 This is the version I had in my Mk2.5 2010 Titanium http://www.ebay.co.uk/itm/FORD-NAVIGATION-SD-CARD-SAT-NAV-MAP-GENUINE-EUROPE-UK-2010-FX-LSRNS-KUGA-MONDEO-/262076531743?hash=item3d04fa841f http://www.ebay.co.uk/itm/FORD-FX-LS-RNS-navigation-sd-card-genuine-sat-NAV-MAP-Version-2010-navi-/201431657531?hash=item2ee6432c3b There is a 2011 version but i'm not 100% that it works http://www.ebay.co.uk/itm/GENUINE-FORD-SAT-NAV-NAVIGATION-SD-CARD-2011-WESTERN-EUROPE-FOCUS-MODEO-/301757685359?hash=item464228de6f Quote Link to comment Share on other sites More sharing options...
JW1982 Posted October 4, 2015 Share Posted October 4, 2015 Ford still sells maps for most original sat nav systems. New maps (CD's) are even available for the focus MK1 (Travelpilot DX). The Travelpilot FX uses SD cards which are specifically for this system. These SD cards are not used for any other Ford sat nav systems. These cards should have the text "FX" printed on the label. SD cards for newer Ford models with the Bosch/Blaupunkt MFD sat nav system are not compatible with the Travelpilot FX. MFD SD cards have a version number (V1 to V5) or the text "MFD" printed on the label. The latest (2015) SD card for the Travelpilot FX does also include a CD. This CD contains a firmware upgrade for the Travelpilot FX. Without this firmware upgrade the maps will not be detected on units running on older firmware versions. The Ford (Blaupunkt/Bosch)sat nav systems uses TeleAtlas maps. TeleAtlas is currently owned by tomtom. Next to the Ford dealer tomtom does also supply the SD cards for most Ford models. The normal retail prices of the Ford dealer and tomtom are basically the same. In the Netherlands Ford often has reduced prices for sat nav maps. Currently the 2015 maps for most sat nav systems are offered for €79,-. Quote Link to comment Share on other sites More sharing options...
bigup Posted October 14, 2016 Share Posted October 14, 2016 On 04/07/2013 at 9:42 PM, Trigger1984 said: Can anyone help i'm trying to find out if this ford sat nav system is run by a disc or sd this in my 2009 focus Quote Link to comment Share on other sites More sharing options...
bigup Posted October 14, 2016 Share Posted October 14, 2016 chaps, I have the Sat Nav head unit same as original poster is there any way of getting DAB on it? Quote Link to comment Share on other sites More sharing options...
Stejones Posted October 14, 2016 Share Posted October 14, 2016 Take a look at www.autodab.com. I've used one of these on a Mk2.5 and can really recomend it. 1 Quote Link to comment Share on other sites More sharing options...
ForTim Posted November 15, 2016 Share Posted November 15, 2016 http://fordnavigation.uw.hu/ "The aim of this site is to give a short overview about the satellite navigation systems, which were pre-installed in the car by Ford of Europe." Quote Link to comment Share on other sites More sharing options...
