Hyrule Posted July 6, 2013 Share Posted July 6, 2013 So I bought this http://www.ebay.co.uk/itm/FORD-FOCUS-ILLUMINATING-MOD-LED-IGNITION-BARREL-RING-BLUE-ILLUMINATED-LIGHT/330700362369?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D286%26meid%3D8888709968148688917%26pid%3D100005%26prg%3D1048%26rk%3D1%26sd%3D230922600323%26#ht_13275wt_1172 and went about fitting it today. Was a bit fiddly in places especially when figuring out how to get the wiring across to the courtesy light, but the most difficult part was getting the LED ring to stay in place when fitting the lower fascia of the steering wheel column back in place. On closer inspection of the plastic LED ring, several of the LEDs were not soldered on properly and the plastic itself was extremely flimsy. After about an hour of faffing about trying to get it to stay in place, one of the LED's popped off and then the entire ring refused to light up. Now I thought to myself maybe I was just to heavy handed, but in comparing the LED ring I received, to the one in the guide, there were differences. Mine: Guide. Notice the black tape over the led ring. Mine came with some cheap plastic. Plus a lot of the wiring was exposed unlike the picture below. The plastic ring did not come with any of the black tape surrounding it, covering the LED pins that are soldered on. The pins were exposed making the whole ring very brittle and easily broken. Alot of the wiring was exposed as opposed to housed in the plastic loom cover. The connectors required a bit of bending in order to fit the courtesy light connections. I can only summise its the cheap/tacky part this seller is providing which is the issue, I guess I should have read the feedback more thoroughly before purchasing. I'll have another go next month via a different seller and hopefully wont have any of the aforementioned issues. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 6, 2013 Share Posted July 6, 2013 Who did you buy yours from? I got mine from a seller called Jooseloosener. Quote Link to comment Share on other sites More sharing options...
Hyrule Posted July 6, 2013 Author Share Posted July 6, 2013 The seller was: watchage222 I'll be ordering from Jooseloosener for the replacement as seems to be the most reliable one. Just annoying spending time getting everything into place to be lumbered with a crappy cheap part. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 8, 2013 Share Posted July 8, 2013 I bought mine from watchage, and I too have an issue where one of the three LED's wont light up. I am not too worried though as it still looks ok, but yours is a bit more extreme of an outcome! Quote Link to comment Share on other sites More sharing options...
Hyrule Posted July 8, 2013 Author Share Posted July 8, 2013 I bought mine from watchage, and I too have an issue where one of the three LED's wont light up. I am not too worried though as it still looks ok, but yours is a bit more extreme of an outcome! Hehe I was cursing his name when it eventually gave up. after getting all the wiring in place. Took over 2 weeks to arrive as well to compound the issue. Why are there no UK sellers ;( Hopefully the other seller will provide better parts. Quote Link to comment Share on other sites More sharing options...
Gary Minty Jupe Posted July 8, 2013 Share Posted July 8, 2013 Ben the seller Jooseloosener is the guy i got my DRL's from he is very helpful and also has a uk return address if needed Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 8, 2013 Share Posted July 8, 2013 With regards the Iginition barrel, the wiring is all in place, so when you get a replacement, just cut the LED end off, and then just wire the posi and negi into the existing wiring, saves you ripping it all out :) Quote Link to comment Share on other sites More sharing options...
Hyrule Posted July 8, 2013 Author Share Posted July 8, 2013 Ben the seller Jooseloosener is the guy i got my DRL's from he is very helpful and also has a uk return address if needed Yeah just about to order one from him now. ;) Yeah will use the existing cable jeebo Quote Link to comment Share on other sites More sharing options...
alkyz89 Posted July 29, 2013 Share Posted July 29, 2013 probably too late but found a uk seller... not on eBay but i purchased most of my mods from him and even supplied him with loads of pics for his page. www.facebook.com/FocusEssentials Quote Link to comment Share on other sites More sharing options...
Lenny Posted July 29, 2013 Share Posted July 29, 2013 probably too late but found a uk seller... not on ebay but i purchased most of my mods from him and even supplied him with loads of pics for his page. www.facebook.com/FocusEssentials Thanks for the link Aaron delivery from this seller within the UK will avoid risk of paying import tax when purchasing from outside of the EU aswell as arrive 10 days quicker Excellent stuff 1 Quote Link to comment Share on other sites More sharing options...
Hyrule Posted July 30, 2013 Author Share Posted July 30, 2013 probably too late but found a uk seller... not on ebay but i purchased most of my mods from him and even supplied him with loads of pics for his page. www.facebook.com/FocusEssentials Yeah good find, albeit Jooseloosener only took 10days to come from china and no import duty. But UK seller +1 1 Quote Link to comment Share on other sites More sharing options...
