dezwez Posted April 4, 2009 Share Posted April 4, 2009 hi if i took a Generic Electronic Module from one focus and fitted it to another would it work in that focus thanks in av Quote Link to comment Share on other sites More sharing options...
mintalkin Posted April 4, 2009 Share Posted April 4, 2009 it would have to be reprogrammed to work. Quote Link to comment Share on other sites More sharing options...
dezwez Posted April 4, 2009 Author Share Posted April 4, 2009 it would have to be reprogrammed to work. wouldnt it be programmed already from the other car thanks Quote Link to comment Share on other sites More sharing options...
SierraYankee99 Posted April 4, 2009 Share Posted April 4, 2009 No, they are programmed vehicle specific not model specific. Quote Link to comment Share on other sites More sharing options...
dezwez Posted April 4, 2009 Author Share Posted April 4, 2009 No, they are programmed vehicle specific not model specific. right thanks any idea how much they sting for it Quote Link to comment Share on other sites More sharing options...
SierraYankee99 Posted April 5, 2009 Share Posted April 5, 2009 Probably at least an hours labour £70-£100 depending which dealership you use Quote Link to comment Share on other sites More sharing options...
dezwez Posted April 5, 2009 Author Share Posted April 5, 2009 Probably at least an hours labour £70-£100 depending which dealership you use thanks ;) Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted May 17, 2014 Share Posted May 17, 2014 Its actually model specific. You can take the GEM from one focus and move to another. The program is only required if you take the GEM lets say from a LX Focus and move to a Titanium. As certain features are turned off. That's why if you have a LX you place a Titanium GEM in you unlock features you would have never had before. Programming is just a list of features that are meant to be on or off, that's how the Elmconfig cable works. This thread may be old but just needed to clarify what actually happens. You can put replace a GEM best idea is to replace with a car with more spec or same as yours not one that is lower spec or you may lose features and then you will need the program to enable them. 1 Quote Link to comment Share on other sites More sharing options...
