bacahill Posted August 16, 2013 Share Posted August 16, 2013 I've just made an account on this forum so hello guys, nice to meet you all ;) So I thought you might be able to help me with a leak problem on my mk1 focus (51 plate). I've had a small leaking problem in the passenger side footwell since I bought the car about a year ago. It was never much so it didn't really bother me. Lately though, it's been raining pretty heavily and the puddle gets bigger each time. Luckily for me, I have thick ford mats that stop most of the water from soaking into the carpet. From the inside, you can see that the water has come from behind the dashboard in the center. I've read that the pollen filter can quite often be the cause of the problem, but I was wondering if there's anything else that it could be. It might be worth mentioning that someone has done an awful job at putting the scuttle cover on - there's a bit gap (about 0.5-1cm) between the bottom of the windscreen and the scuttle itself. It also has 2 screws missing from it so I'm not sure if this is affecting what I assume is supposed to act as a gutter. If anyone can help me out with what's causing it, I'd greatly appreciate it. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted August 16, 2013 Share Posted August 16, 2013 it will be the pollen filter a revised scuttle panel should have been fitted and the filter seal will need replaced as well to prevent water leaks Quote Link to comment Share on other sites More sharing options...
bacahill Posted August 16, 2013 Author Share Posted August 16, 2013 Thanks for the reply, I'll get a replacement and if you don't here any more from me, it worked! :) cheers Quote Link to comment Share on other sites More sharing options...
