Tdci Problem
BenHancock
Hi there,
Sorry my first post is a question, but I have a problem with my focus.
It's a 2003 Focus Zetec Estate with a 1.8 TDCI (115).
It seems to have a loss of power over 3000rpm. It only happens when the engine is up to temperature and under load. It happily boosts up to 3000rpm and feels powerful, but from then on its like driving through custard.
It feels like the engines holding back at full throttle, sometimes it will hesitate and stutters it's way up to the redline. Other times it will just struggle to climb up the revs. From cold it flies to the redline. And it only happens over 3000rpm.
I had the fuel pump done as it felt like it was underfueling. Diagnostics threw up the crankshaft sensor but that has now been sorted. No other faults are showing. I've also tried some fuel additive and given it an Italian tune up. Nothing has helped so far.
Does anyone have any ideas? Please?
Thanks in advance
Ben
When did you last change the fuel filter? I would start with that unless you've changed it very recently.
Thanks for your help.
It was done within the last 5000 miles. Would it be worth doing again?
Are there 2 fuel filters or just the one?
There's just the one filter. It should last a bit more than 5000 miles but you could have had some dirty fuel from somewhere which has clogged it. When you change the filter check the housing for cracks and make sure the fuel lines are secure as air could be getting in. It certainly sounds like you have some sort of fuel delivery problem.
Was it always like that?
Looking at the power curve -
http://www.mybluefin.co.uk/curves/focus18tdci115bhp-d.pdf
it rises steeply untll a little over 3k, then its basically goes "flat" - and thats a car in good condition, probably almost new, yours is 10 years old, the interooler will be clogged up with oil from the breather, your inlet manifold will be all choked up from the EGR system
So it may not be fuel related at all - or if it is - it could be the inectors
It may be the engine is being "choked" (the "breathing" is being restricted) -
Presumably you have changed the air filter (i do mine every 6 months or 6k)
So if you take off the intercooler, clean it out with petrol, and take the inlet manifold off and clean all the carbon/ muck uot of it, that may "fix" it
I recommend you fit an EGR blanking plate (solid, stainless steel) this will prevent the inlet from being clogged up again, and help the performance, economy and reliability of the car (a bit) - many FOC members have blocked their EGR valves now
The exhaust can also get choked (especially if the engine smokes a lot) the cat can get glogged - the italian-tune up helps
Cheap, pattern fuel filters can restrict the flow of the fuel - better with a Genuine Ford or "premium"/ quality branded filter
If the above does not work you can always get a remap, decat, etc (the engine can be mare surprisingly powerful) or just change up at 3k - (keep it in the powerband - between 2k & 3k) because its never going to rev like a racing motorcycle engine :lol:
[quote name="BenHancock"
Ben
Serious? 1 of the quickest ways to kill a engine.....
Yeh I guess it would be worth doing again. I will get that done this week. I always use decent branded fuel as well as I've heard bad things about supermarket diesel.
Thanks for the help.
It hasn't always been like it. Only in the last few thousand miles. Engines done 70k.
Air filter was done 5000 miles ago so that will be another thing I order this week.
I have read about the egr. Mine isn't smokey but I will be blanking it off to see if it helps. Does an egr valve work through the rev range or is it only open lower down?
I will also try and clear all the deposits in the manifold, inter cooler etc.
Thanks again
Not standard practice. I know it's terrible but it was just to help diagnose the problem.
Ben
Egr valve, buy a plate 4 quid of bay to try
That doesnt look like the ones you normally get, but I have seen them for TDCI as opposed to TDDI, so cant say for definite.
After another full service, the problem seems to have resolved.
I'm guessing a faulty fuel filter or dirty fuel had clogged it as Karlos suggested.
I'm going to blank the egr anyway. Would a 1.5mm stainless steel blanking plate be adequate?
Such as this one.... http://www.ebay.co.uk/itm/231002704510?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
I did try searching on here, but couldn't find a specific answer.
Thanks for everyone's help
Ben
Ben
1.5mm is a bit thin, in my opinion, but is probably ok for plates that are not close to the exhaust.
It is still worth cleaning out the the inlet manifold (by taking it off) as it is liable to be full of carbon / gunge
The sellers spiel is fairly accurate (of course its "dummed down" for a mass audience) exept the (working) EGR system only reduces emmisions when the car/ engine is new, when it is older, once the EGR system has contaninated the inlet, oil, etc etc causing more smoke and poorer MPG, so can have a worse effect on the enviroment than if it had not been fitted at all
A thirstier car can have a worse effect on the enviroment because of the impact producing/ refining/ transporting the extra fuel - even if the actual emmisions are higher - so MPG is important
Resetting the ECU can help after fitting an EGR plate
EGR systems are different on different engines, some work through the rev range at part or trailing throttle, some only at specific revs, even the types that only open at low revs/ on part throttle can produce flat spots or lag/ poor throttle response at some revs that are often eliminated when a solid plate is fitted
