Ford Fiesta Wing Mirror Replacement
mpat89
Hello all!
My passenger side wing mirror recently got ploughed by a pillar when reversing from a parking space. Suffice it say its knackered, and i think it seems to have pulled the plate in which the wing mirror is bolted to the car so the mirror is sticking out at an awkward angle.
I was wondering if anyone would know what this would cost to fix, and whether or not replacing the mirror myself would be a viable option.
Thanks.
I replaced the mirror on my 55 focus zetec climate a few years ago, the mirror assembly was about £80 in total.
To remove the mirror, you need to remove the trim on the inside of the driver window (parallel to the mirror) then you need to remove the bolt, and just follow instinct (remove a few other trims to get at the wiring) then, once you have done that, reinstall in the reverse.
It took me about 20 minutes to refit my old mirror (after I worked out how to get the cabling apart!)
