atherm3 Posted September 24, 2013 Share Posted September 24, 2013 Hi all Looking for advice on an issue I'm facing with my 10 plate petrol focus. My partner reported to me that the car was cutting out when approaching junctions and cornering however this hadn't happened to me, after a bit of covert observations I determined that she takes said corners with the clutch pressed and not in gear, I do not as a general rule of thumb. After a while I managed to replicate it and became more aware of the idle speeds dipping when sat on the drive or at junctions. Its since been through an MOT and had an intermediate service. So my question is, short of taking it in for diagnostics (not priced up yet) or re teaching my partner how to drive (she swears she was taught that way and passed?) What action can I take to resolve it? I have recorded a 30 second video that I can upload to YouTube and link here if needed Quote Link to comment Share on other sites More sharing options...
{{SHC}} WOLFIE Posted September 24, 2013 Share Posted September 24, 2013 Please upload your link, but my Ford Focus 1.8 ltr Petrol did this, sometimes it would cut out sometimes not, as I recall it was down to the cluster, I was advised to cleaned with Lube oil or/and re-solder the mother board. mine seems to be ok recently. I am sure others will better help you than I have. Quote Link to comment Share on other sites More sharing options...
btmaldon Posted September 24, 2013 Share Posted September 24, 2013 It sounds like the Idle Control Valve may be sticking or faulty. Ford refer to this as the Air Idle Valve. It is relatively cheap to replace but I would check that all the vacuum and air hoses are fitted correctly first and that there are no splits allowing air into the intake system. Quote Link to comment Share on other sites More sharing options...
atherm3 Posted September 24, 2013 Author Share Posted September 24, 2013 Hi, thanks for the advice on this, it had been mentioned that the idle control may be the culprit in passing conversation with a friend, here is the link https://www.youtube.com/watch?v=NKJZLvORZMM&feature=youtube_gdata_player Quote Link to comment Share on other sites More sharing options...
atherm3 Posted September 24, 2013 Author Share Posted September 24, 2013 https://www.youtube.com/watch?v=NKJZLvORZMM&feature=youtube_gdata_player Quote Link to comment Share on other sites More sharing options...
artscot79 Posted September 25, 2013 Share Posted September 25, 2013 from that video it sounds like its meant to the idle is ecu controlled so no idle control valve and the ecu determines this on various factors engine temp outside temp etc etc to reduce idle emissions the engine effectively reduces the idle speed constantly to get the lowest emissions do the dash trick go to rpm and watch it if its 750 or above theres noithing wrong woith the car its just the mrs driving im afraid and driving the way she does means shes not in control of the car driving that way so god knows who passed her no offence mate not trying to be rude i think the issue is the mrs driving not the engine Quote Link to comment Share on other sites More sharing options...
atherm3 Posted September 25, 2013 Author Share Posted September 25, 2013 Aye no offence taken, her argument to that is (despite not driving safely really) the car shouldn't cut out at all, and it's quite difficult to really go against that notion as it doesn't have stop/start technology and it's not a feature of the car. I think I'll get it in for diagnostic tests. Thanks all, Quote Link to comment Share on other sites More sharing options...
artscot79 Posted September 25, 2013 Share Posted September 25, 2013 no it shouldnt cut out however the speed sensor and throttle sensor will realise the car is cornering and not in gear it may be cutting the fuel as it thinks something is wrong Quote Link to comment Share on other sites More sharing options...
