Wiring Diagrams (Cruise Control)
Musketter
I am after a wiring diagram for a 59 1.4 DIesel, esp to do with the dash/cruise control wiring.
I have the cruise control working but have a loose conection somewhere which means when I hit a bump it sometimes cuts the cruise control off, then sometimes I have to wait for another bump before I can switch it back on.
I have tried the Haynes manual one but it doesn't show it. I have also tried another switch which did the same.
Does anyone know where the two wires from the dash go to from the steering wheel connector block as I don't want to dismantle half the dash tracing wires !
Thanks in advance
The wires from the cruise control buttons join up with the stereo buttons behind the airbag and there's a plug there. From there 2 wires go to another plug in the steering column (usually white + green+brown) those wires then go in to the back of your speedo.
Cheers Nathan, on the ball as ever :)
  • 1 year later...
Sorry to resurrect a year old post but I wondered if you found the problem on yours. My cruise control has a similar intermittent fault - it either works or it doesn't, and I think it is down to a loose or bad connection somewhere.
