nimbo Posted October 6, 2013 Share Posted October 6, 2013 I have a 2008 transit and have recently had problems with the ignition. On occasions when you turn the key no dash lights come on but the engine will turn over but won't start. If I wobble the key in the barrel I get the normal lights and she starts. Anyone had the same problem or know what's wrong as the situation is getting worse Quote Link to comment Share on other sites More sharing options...
wase16ll Posted October 6, 2013 Share Posted October 6, 2013 most likely the ignition switch itself. the switch is a plastic connector and available seperately from the lock assembly Quote Link to comment Share on other sites More sharing options...
nimbo Posted October 6, 2013 Author Share Posted October 6, 2013 Oh thanks, So a simple replacement then....? Quote Link to comment Share on other sites More sharing options...
wase16ll Posted October 6, 2013 Share Posted October 6, 2013 fairly straightforward yes Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted October 7, 2013 Share Posted October 7, 2013 Fairly Straightforward in definition, but in practice it can prove to be more difficult. I would recommend either a Haynes Manual and a good general knowledge, or a good indie garage! Quote Link to comment Share on other sites More sharing options...
