t3stin Posted October 13, 2013 Share Posted October 13, 2013 a few weeks back in traffic the gear stick went floppy, lifting the gaiter up showed the problem to be a rod that had fallen off a ball shaped joint and pushing it back on solved the problem. It has now happened twice more and i'm becoming worried at the frequency of it happening, I have circled in the attached picture the rod that falls off the ball - can i buy a new replacement rod or replace the rubber bit to stop it slipping off anymore? Is it a common fault or has anyone else experienced this / found a fix? I'm not entirely sure what the rod is called so I wouldn't know what i'm looking for. All ideas and suggestions very welcome - I have no idea unfortunately! Tess Quote Link to comment Share on other sites More sharing options...
msajohnson94 Posted October 13, 2013 Share Posted October 13, 2013 you most likely can pick it up from the ford dealership. that is the gear linkage. best to replace the rubber joint it should solve the problem. is there much ware on the metal ball atall and is there much ware on the rubber joint? Quote Link to comment Share on other sites More sharing options...
t3stin Posted October 13, 2013 Author Share Posted October 13, 2013 Doesn't appear to be any wear to either - any idea on the price of the rubber joint? Does it just pull off and then slide the new one on? Thanks Quote Link to comment Share on other sites More sharing options...
msajohnson94 Posted October 14, 2013 Share Posted October 14, 2013 im unsure of the price for one. i think it should slide of. best to talk to you local dealer for a price Quote Link to comment Share on other sites More sharing options...
