tkeenan2107 Posted November 7, 2013 Share Posted November 7, 2013 hey everyone wondered if anyone could help, 3 days ago I purchased a mondeo mk3 tdci privately, and for the past day or so iv been having problems starting it, I turn the key in the ignition and the immobiliser, flashes away at me, at first it took a few attempts at turning the key to get it to go through and start the engine, I took it down to a local garage and he said what it seems to him is that one key with the 3 buttons opens and locks but the other just turns the ignition barrel so advised me to hold the 3button key close to the barrel, this I thought worked unil today, today I don't think its took less that 15mintes at a time to get it to start, luckily I have a friend who works at ford so iv took it along to him after explaining my problems over the phone and said the key at turns the ignition just wants coding, so after him telling me the price I took it down and he had a go at recoding it, NO LUCK!, the computer he was using to recode was saying there was a fault and it was possibly the PATS module, but told me to eliminate the ring around the ignition first and purchase one of those, after finding out that the £150 inc VAT a ford I went to a local dismantlers that he said was good and got one, come home changed it over still no luck, so the next thing is the PATS module, what Im guessing I need to know now is where is it? can it be fixed? is it simple and is it expensive? as its my work car so need it fixing to earn my bread and butter, hanks for taking the time to read this, and thanks for the replies if any in advance Quote Link to comment Share on other sites More sharing options...
stooge75 Posted November 7, 2013 Share Posted November 7, 2013 this might be wrong but i just read on another forum that some mk3's had external PATS module beside handbrake & some mk3's have it incorporated into the ECU in tandem with the transceiver around ignition barrel. someone here should know though. I had a similar problem on another car & it drove me crazy! Quote Link to comment Share on other sites More sharing options...
tkeenan2107 Posted November 7, 2013 Author Share Posted November 7, 2013 yes its driving me !Removed! nuts and after having a new key cut at Ford and them programming both keys, on top of purchasing another receiver that goes around the barrel, im trying to eliminate starting from the cheapest and working my way upwards but the only thing I see now it it being what my friend at ford said and that's the Pats module its self, but I haven't a clue when it comes to diagnostics and electrics, so wouldn't even know who to take it to? could it be replaced with another or will it need a whole new ecu? Quote Link to comment Share on other sites More sharing options...
stooge75 Posted November 7, 2013 Share Posted November 7, 2013 on etis it says: Principles of Operation General The passive anti-theft system (PATS) uses radio frequency identification technology and a unique encryption code to deter a drive away theft. Passive means that it does not require any activity from the user. Encoded Ignition Key The PATS uses a specially encoded ignition key. Each encoded ignition key contains a permanently installed electronic device called a transponder. Each transponder contains a unique electronic identification code which may be any one of millions of combinations. Each encoded ignition key must be programmed to the vehicle's PATS control function within the powertrain control module (PCM) before it can be used to start the engine. There are special diagnostic repair procedures outlined in this manual that must be carried out if an encoded ignition key needs to be changed. The PATS transponder key is identified by a blue insert. Previous PATS transponder keys that have a red insert are not compatible with this vehicle and must not be used. Only Ford approved ignition keys should be used as some aftermarket encoded ignition keys not purchased from a Ford approved source may fail to operate especially at extreme temperatures. NOTE: If a non programmed key has been used, further key reading is inhibited for 20 seconds. During this 20 seconds, no ignition key will start the engine. A minimum of 2 encoded ignition keys must be programmed to a vehicle in order for the engine to start. A maximum of 8 ignition keys may be programmed to a vehicle. The PATS control function within the PCM will enter Anti-Scan Mode if an attempt to start the vehicle with a non programmed ignition key (with the correct mechanical cut) is made. PATS Control Function The control functions are contained in the PCM. This module carries out all of the PATS functions, such as receiving the identification code from the encoded key and controlling engine enable. The PCM initiates the encoded key interrogation sequence when the vehicle ignition switch is turned to II or III. When the key is turned to the 0 position, the PCM will remain powered up for approximately five seconds. This is the maximum time allowed for the insertion of a second key to initiate the customer key programming sequence. Transceiver Module The transceiver module communicates with the PATS encoded ignition key. This module is located behind the steering column lower shroud and contains an antenna connected to a small electronic module. During each vehicle start sequence the transceiver module reads the encoded ignition key identification code and sends data to the PATS control function within the PCM. No re-initialization needs to occur with the removal or installation of a new PATS transceiver. hope that makes it a bit clearer. looks like the PATS IS incorporated into the ECU/PCM mate I'd take it to either a good auto-sparky,or to another Ford dealer. When you told me your mate said to look for the module etc,I thought if you went to Ford as a customer,they wouldnt say that. Their IDS/VMM should be able to pinpoint exactly whats up. Hell I know guys on another forum with IDS that'd definitely crack it,but theyre in another country. ps:Ive PM'd you the self-test guide & wiring diagrams for the PCM/Transceiver. As I said if you're no good with a multimeter,an auto-sparky would suss it out Quote Link to comment Share on other sites More sharing options...
tkeenan2107 Posted November 8, 2013 Author Share Posted November 8, 2013 hi yes he works at the Ford dealership in chapletown, and told me that it seems to be the Pats and his boss even had a play and that's what he said too, and that if it was he would expect it to be an expensive job to fix and maybe more than what the cars worth Quote Link to comment Share on other sites More sharing options...
tkeenan2107 Posted November 8, 2013 Author Share Posted November 8, 2013 could anyone tell me if I could purchase this and swap it with mine?? http://www.ebay.co.uk/itm/FORD-MONDEO-MK3-DIESEL-TDCi-ECU-MODULE-4S71-12A650-GB-Key-Fob-Transponder-set-/141097135529?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20da0b6da9 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 8, 2013 Share Posted November 8, 2013 You should be able to. It may need pairing to the instrument cluster though as, if a Mondeo's systems are like the Focus, the cluster is an integral part of the immobiliser system. Quote Link to comment Share on other sites More sharing options...
tkeenan2107 Posted November 8, 2013 Author Share Posted November 8, 2013 Would it be a case of swapping them over and having it reprogrammed? Quote Link to comment Share on other sites More sharing options...
stooge75 Posted November 8, 2013 Share Posted November 8, 2013 Would it be a case of swapping them over and having it reprogrammed? yes.someone who's got IDS/focom etc will be able to prog it all Quote Link to comment Share on other sites More sharing options...
tkeenan2107 Posted November 8, 2013 Author Share Posted November 8, 2013 Thanks for the feedback it really is appreciated, iv been and purchased the ecu/pcm and all the barrels, only 1 key though so hoping he will programme my other one, going to have a go at changing them all over in the morning then call out the local auto electrician, i just hope its not a brake in the wiring Quote Link to comment Share on other sites More sharing options...
stooge75 Posted November 8, 2013 Share Posted November 8, 2013 ok.was it giving you any codes? Is it communicating with ecu & immobiliser? guy on other forum is asking.he thinks you're doing the wrong thing by installing the other ecu etc right away,in case its something else(thats correctable) upto you though.good luck :) Quote Link to comment Share on other sites More sharing options...
tkeenan2107 Posted November 9, 2013 Author Share Posted November 9, 2013 Hi i believe it is communicating as and when it wants to, like i said its been taking about 100 turns of the key and thats not 1 less, it really has become a nightmare and its just a case of pot luck if it starts or not, when my friend had it hooked up to his computer it was coming back as a pats module fault, so i bought a ecu&pcm and all the door locks and matching keys yesterday from a local garage that just deals with ford and he said that he would be amazed if what im doing didnt fix it Quote Link to comment Share on other sites More sharing options...
tkeenan2107 Posted November 9, 2013 Author Share Posted November 9, 2013 Well had a pig of a day today got to ecu out to find out i purchased the wrong one but the guy i got it from was good enough to give me a refund so try agaib tomorrow Quote Link to comment Share on other sites More sharing options...
stooge75 Posted November 9, 2013 Share Posted November 9, 2013 not so good then. do you know what ecu you need now then? just outta curiosity did it show any codes when it wouldnt start(when the guy at ford hooked it up to IDS?). guy on another forum is asking. was it communicating with immobiliser system? he seems to think it should have a specific code if its not communicating with PATS. when i told him that its only 1 in 100 turns he maintains its probably not the ECU Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 9, 2013 Share Posted November 9, 2013 I'm inclined to agree, it could just be the transponder ring around the ignition barrel. Quote Link to comment Share on other sites More sharing options...
stooge75 Posted November 9, 2013 Share Posted November 9, 2013 he replaced the transceiver with one from scrappys though. I have a feeling its something silly. forgot to ask you. did you do an ECU reset? also,try having a read of this:http://www.fordpats.com/ the part under where it says new data from our readers i know its not for mk3 mondeo but its same PATS system.you never know Quote Link to comment Share on other sites More sharing options...
tkeenan2107 Posted November 10, 2013 Author Share Posted November 10, 2013 Hi when he hooked it up all it showed was -pats module fault so he said go to the scrap yard down the road and purchase another transponder ring for the ignition barrel which i did got it home replaced that amd still no luck! So that left it down to the ecu as the pats is encorperated into it, yes i purchased a Bosch ecu which was wrong as mines a delphi, but with the Bosch one i got all the locking barrels to the ecu but the delphi one i havent so the guy i purchased the Bosch one from has been kind enough to give me a set just means having 2 seperate keys Quote Link to comment Share on other sites More sharing options...
Dan62 Posted November 10, 2013 Share Posted November 10, 2013 . Quote Link to comment Share on other sites More sharing options...
tkeenan2107 Posted November 10, 2013 Author Share Posted November 10, 2013 the ecu i purchased yesterday only has 1 key with it and not the matching locks just the 3 fob key the matches the ecu so when i purchase the locks ill then have 2 seperate keys Quote Link to comment Share on other sites More sharing options...
tkeenan2107 Posted November 10, 2013 Author Share Posted November 10, 2013 No the original key matches up with the ecu, all the codes matched, but for some reason it wasnt reading them correctly so he ran a test on it and it came back pats module fault, Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 10, 2013 Share Posted November 10, 2013 No need to fit the ignition barrel. Just use the ECU/ring/fob and swap the key blades over so the key still operates the door locks and ignition. A type 2 (horseshoe) key has the transponder chip in the fob whereas a type 3 (flip) key has the transponder in the removable blade section. Quote Link to comment Share on other sites More sharing options...
tkeenan2107 Posted November 10, 2013 Author Share Posted November 10, 2013 Funny you should just say that, the brother in law has just rang to say we will do that today, and hopefully get the auto electrician out Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted November 10, 2013 Share Posted November 10, 2013 Daft to faff about changing the barrel when all that needs doing is the transponder etc. Saves about an hours work and having the pain of two different keys to the car. Quote Link to comment Share on other sites More sharing options...
