jomp Posted November 13, 2013 Share Posted November 13, 2013 Hi I've a problem with my 2009 1.8td Galaxy, every now and again while driving along 'Engine malfunction' is displayed on the dash and car enters limp mode.Turn car off for 30secs and restart and its back to normal. I've taken it to local garage to get plugged in, Both times the fault code 'Injector no.2 open/broke' comes up. He told me he can't say exactly what this is but next time it happens he will take injector out, get it tested and take it from there. It's happened again tonight and while I could take it straight to main dealer and get it sorted i'd rather give the work to my local mechanic, but not wanting to be left without the car for long while he traces the problem, so if anyone maybe knew the exact meaning of the fault code that would be great. Many thanks guys for any replies Jomp Quote Link to comment Share on other sites More sharing options...
wase16ll Posted November 13, 2013 Share Posted November 13, 2013 not as easy as that im afraid, fault codes dont give exact meanings, its just showing you where the problem is being noticed, not why the actual code might help give some ideas, dont think ive come accross 'injector open/broke' Quote Link to comment Share on other sites More sharing options...
jomp Posted November 13, 2013 Author Share Posted November 13, 2013 Thanks Wase16ll I cant remember the exact code I think it was 9212? Quote Link to comment Share on other sites More sharing options...
wase16ll Posted November 14, 2013 Share Posted November 14, 2013 the mechanic is probably right you can monitor the injectors in live data while engine running, but only if you can get the problem to occur. might pay to do a leak test on all the injectors [i take it we are talking about a diesel] before removing if you do decide to have it checked out elsewhere, then probably better off with a diesel specialist rather than main dealer, if its a petrol engine, then problem could be a lot easier to diagnose as it wont need so much specialist equipment Quote Link to comment Share on other sites More sharing options...
jomp Posted November 14, 2013 Author Share Posted November 14, 2013 Thanks again Wase16ll. Yeah its a diesel. The mechanic said he would take the injector out and send to get tested. Quote Link to comment Share on other sites More sharing options...
mick85 Posted November 17, 2013 Share Posted November 17, 2013 Did u take it to main dealer Quote Link to comment Share on other sites More sharing options...
mick85 Posted November 18, 2013 Share Posted November 18, 2013 If it intermittent it's wiring issue I would be checking that first Quote Link to comment Share on other sites More sharing options...
mick85 Posted November 18, 2013 Share Posted November 18, 2013 Open circuit on injector 2 so it not spraying fuel in put car into limp mode protect engine Quote Link to comment Share on other sites More sharing options...
