Turvey Posted December 14, 2013 Share Posted December 14, 2013 Inspired by a comment in and not wanting to spoil the 'What did you buy your Ford for Christmas' thread... Two new rear tyres due to punctures, full alignment/balancing, nitrogen filled all tyres and new numberplate holders. How do you find the ride now Clive? Is there a significant difference? No-where up here to get it done and I don't know if I would actually splash out on it but interested in what others think ;) Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 14, 2013 Share Posted December 14, 2013 Using pure Nitrogen in tyres is supposed to reduce pressure changes due to tyre temperature and reduce leaks as Nitrogen molecules are larger than Oxygen molecules therefore maintaining tyre integrity. TBH it's probably a load of cobblers but does sound cool. Saying that F1 and aircraft manufacturers have been using Nitrogen for years so who's to say (although those tyres are meant to take a lot more abuse heat wise). It was £1.50 per tyre at Kwik-Fit with free top-up's as needed- I know, not the best bunch around but when you have two tyres going down and the tyre place is at the end of your road what are you to do? Personally I feel the wheels seem more stable but could just be due to two new Goodyears on the car and the fact my tracking and balancing was way off. All in all I think it's personal choice. Quote Link to comment Share on other sites More sharing options...
Old George Posted December 14, 2013 Share Posted December 14, 2013 I had new Goodyears fitted all round on Thursday by tyresonthedrive. Then i called in at a local independent tyre fitter to have the tracking checked, they advertise nitrogen filling and i was wondering if there are any tangible benefits? Quote Link to comment Share on other sites More sharing options...
georgen Posted December 14, 2013 Share Posted December 14, 2013 Stoney hit it on the head with the first part of his explanation ;) Quote Link to comment Share on other sites More sharing options...
TDCiST Posted December 14, 2013 Share Posted December 14, 2013 I've found that my pressures stay more balanced and I don't need to top up as much... As for wear and ride etc, not much dofferemce Quote Link to comment Share on other sites More sharing options...
Willy Posted December 14, 2013 Share Posted December 14, 2013 Fifth gear recon it's not worth the extra cost :p Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 14, 2013 Share Posted December 14, 2013 Tiff doesn't recommend it. Aw shucks! One persons opinion doesn't make a majority ;). Personally I just think it's a good posing point- "You only have boring old air in your tyres? Poor you" :p Quote Link to comment Share on other sites More sharing options...
TomTitanium62 Posted December 16, 2013 Share Posted December 16, 2013 Love the fact that tiff said "if your not checking your pressures regularly you shouldn't be on the road at all" a point i always stress to people ! don't think some people realise the dangers and how you can loose control of your car with under inflated tyres. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 16, 2013 Share Posted December 16, 2013 Tiff is the king of stating the bleeding obvious. Still prefer Top Gear anyway, 5th Gear is boring in comparison. Quote Link to comment Share on other sites More sharing options...
b1g_dav3 Posted December 16, 2013 Share Posted December 16, 2013 I never check my tyre pressures >_> This is why I purposely bought sensors >.< Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 16, 2013 Share Posted December 16, 2013 I personally never noticed any difference on the nitrogen front lol. Had the nitrogen put in my new tyres and didnt feel any different. The car never lost air at any less a rate than it has before! Im just glad they dont charge more than £1.50, but Kwik Fit have recently taken to just charging customers for the use of Nitrogen. Sadly they used the excuse the air compressor wasnt working with one customer I was near Quote Link to comment Share on other sites More sharing options...
Willy Posted December 16, 2013 Share Posted December 16, 2013 Don't forget that your tyres also have air in them. They don't remove it when they put the nitrogen in ;) Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 16, 2013 Share Posted December 16, 2013 :O sacrilege! I paid for Nitrogen, not Air! eesh! Quote Link to comment Share on other sites More sharing options...
stevegtuk Posted December 16, 2013 Share Posted December 16, 2013 Personaly I think its just a con. All it will do is make people think they dont need to check their tyre pressure because it supposedly wont go down, so, as tiff pointed out at the end they wot know if they have a slow puncture or a leak. Also if you do check the pressure regularly, each time you stick the pressure gauge on, a little air always leaks out, so you either leave it or top it up. unless you go back and pay another £1.50 you will put fresh air in so will defeat the idea of nitrogen anyway. 1 Quote Link to comment Share on other sites More sharing options...
FOCA Posted December 17, 2013 Share Posted December 17, 2013 Don't forget that your tyres also have air in them. They don't remove it when they put the nitrogen in ;) They are supposed to let all the air out 1st before they fill the tyres with nitrogen Quote Link to comment Share on other sites More sharing options...
Old George Posted December 17, 2013 Share Posted December 17, 2013 I'll use Helium to lighten the steering! :D 1 Quote Link to comment Share on other sites More sharing options...
jamesm182 Posted December 17, 2013 Share Posted December 17, 2013 I personally think it's a bit of a con. Can't see it make that much improvement to be worth it for the hassle. What happens if you have a flat or your tyre is 10psi down before a long journey. You need to top it up but you can't find anywhere that's open and sells nitrogen. 'Oh no.... what am I going to do? I can't just put poverty spec air in there!!' :P I like the fact the I can get my air from anywhere including my foot pump! :D Quote Link to comment Share on other sites More sharing options...
TDCiST Posted December 17, 2013 Share Posted December 17, 2013 I've never paid for nitro inflation ;) always haggle it lol! If they are gonna do it for free who cares lol Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 17, 2013 Share Posted December 17, 2013 wrong thread there Mick? lol Quote Link to comment Share on other sites More sharing options...
mick85 Posted December 17, 2013 Share Posted December 17, 2013 Haha sorry guys I have no idea how that got there lol u idiot mick ha Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted December 17, 2013 Share Posted December 17, 2013 Deleted your brain f a r t. ;) Quote Link to comment Share on other sites More sharing options...
Old George Posted December 17, 2013 Share Posted December 17, 2013 £1.50 per tyre at Kwik-Fit, anyone else think the price is a bit inflated?....................(I'll get me coat!) :P :D 1 Quote Link to comment Share on other sites More sharing options...
