kazacat Posted April 20, 2009 Share Posted April 20, 2009 Hi Guys... Hopefully someone will have a few ideas and fixes for this little "issue...." My KA has optional A/C fitted.... system is fully charged and WAS working last time it was warm.... Just tried to use it this afternoon and found that even though switch on the dash illuminates ON and OFF ok, the clutch on the A/C pump doesn't throw in or out... result is that although the system is charged, and the pump spins..... it doesn't engage the clutch (i assume thats the case...) and the A/C doesn't work. Fuse no. 17 on the dash panel is OK and no odvious issues with the wiring is evident..... Anyone got any ideas / hints or has anyone else had the same problem ?? Thanks in advance of any help you can give me..... Kazacat Quote Link to comment Share on other sites More sharing options...
TurboZutek Posted May 21, 2009 Share Posted May 21, 2009 Fuse no. 17 on the dash panel is OK and no odvious issues with the wiring is evident..... Anyone got any ideas / hints or has anyone else had the same problem ?? Thanks in advance of any help you can give me..... Kazacat I'd get a multimeter (or even a simple bulb or buzzer) onto the terminal for the clutch - check if power is getting to it. If it IS, then I'd suspect the clutch as being buggered. Chris... Quote Link to comment Share on other sites More sharing options...
gaz6076 Posted May 21, 2009 Share Posted May 21, 2009 Have you checked the relay? Quote Link to comment Share on other sites More sharing options...
Big Bob Posted May 22, 2009 Share Posted May 22, 2009 I'm having a similar problem with my Fusion at the moment. How do you know that the system is fully charged? In my investigations so far it seems that if the pressure is low then the system shuts down the feed to the mag clutch, to prevent damage. If your system is fully charged then perhaps the pressure sensor is faulty. As the Haynes book of knowledge for the Fiesta (Fusion) does not appear to have much on A/C, are there any on line diagrams for this system? Quote Link to comment Share on other sites More sharing options...
