Electric Window Not Working
My front drivers side electric windows has stopped working... it was working fine this morning however this evening on the way home it has stopped working. The front passenger side window is working fine.. from both the controls on the passengers side and drivers side control/buttons..
The car is a 2001 ford focus... it only has electric front windows. What do i need to check.. is there a separate fuse for each window or anything like that.. I simple fix or something?
Thanks in advance guys
Check fuses first then remove door card use circuit tester or multimeter check u getting voltage down to reg block connector if u don't most likely switch is problem
Thanks.... is there one fuse for both electric windows... or a separate fuse for each window.
The passenger side window works from the controls on the drivers door.
Thanks again
Most likely it's your switch have u got a circuit tester an manual off car
nope not got a circuit tester. but have got access to a haynes manual
U really need circuit tester at the least u can buy for less den 20 if u mess round with car electrics circuit test an a multimeter are a must for diagnostics the will save u money in long run
Check fuses 37, 40, 43, and 56 in the fuse board behind the glove box.
Thanks... checked the fuses. All of those ones are fine. Fuse no 56 is the one for the electric windows.
When I press the button for the drivers side window it makes one click noise but nothing happens. when i press the button for the passenger window from the same control panel it works.
So does this sound like the motor for the drivers side window has died?
Does pretty much sound like the motor.
MK1 Focus' are prone to water ingress into the door electrics.
is replacing the motor quite a cheap and easy fix?
They very expensive second hand be ur best bet but u wanna be checking make sure power getting down to the motor
  • 6 months later...
Got a replacement 2 pin drivers side window motor and regulator for 02
focus. New part doesn't have the electrical connector attached to the
motor. Instead has two wires with pins. Is it simply a matter of
swapping the old connector over to the new part or have I the wrong
part?
Compare the part numbers of the old and new regulator but it sounds like the wrong one to me. Either that, or you might find that the casing is on the wiring side and that the existing regulator plugs in the same way.
