Probably75 Posted January 27, 2014 Share Posted January 27, 2014 Last week the Dpf on my 55 plate focus 1.6 tdci blocked and blew a pipe. Since then I have had it changed and also the turbo replaced. The car is still under powered and you can hear a hissing coming from under the bonnet every time you put your foot down. Can anyone help me. Quote Link to comment Share on other sites More sharing options...
Euro4-Climate Posted January 27, 2014 Share Posted January 27, 2014 Check the rubber pipe between the intercooler and the turbo. Mine split (apparently it's a common occurrence) and produced a hissing noise during acceleration. Quote Link to comment Share on other sites More sharing options...
Probably75 Posted January 27, 2014 Author Share Posted January 27, 2014 Cheers for that ill let u know Quote Link to comment Share on other sites More sharing options...
Probably75 Posted January 28, 2014 Author Share Posted January 28, 2014 You haven't got a drawing to show how to replace and find the intercooler pipe have yo? Quote Link to comment Share on other sites More sharing options...
Euro4-Climate Posted January 28, 2014 Share Posted January 28, 2014 I've done a guide with photos (see my signature), but that's for the 1.8 TDCI. You would need to compare the under bonnet view of your car, to the photos in my guide, to see if the layout is the same (or sufficiently similar) to allow you to make use of it. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 28, 2014 Share Posted January 28, 2014 The pipe should still be to the drivers side of the engine. Quote Link to comment Share on other sites More sharing options...
Probably75 Posted January 30, 2014 Author Share Posted January 30, 2014 Just to let people know my problem has been fixed. It ended up being a split in the intake manifold. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted January 30, 2014 Share Posted January 30, 2014 Ouch. Quote Link to comment Share on other sites More sharing options...
Probably75 Posted January 30, 2014 Author Share Posted January 30, 2014 Note to ones self make sure to replace dpf when needed! Quote Link to comment Share on other sites More sharing options...
