karlos1987 Posted February 3, 2014 Share Posted February 3, 2014 Hi. I'm new to the forum so please bear with me. Can anyone advise me on changing my front and rear bumpers to St ones. My car is a ford focus mk2.5 titanium 5 door. I'm wondering if I can literally just unbolt my current bumper and replace with St bumper with out any hassle. Any advice would be greatly appreciated. Karl Sent from my C5303 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
DarrenW94 Posted February 6, 2014 Share Posted February 6, 2014 As far as i am aware for the front bumper you will have to get the grilles and fog mounts but the bumper itself will fit straight on, as for the rear i wouldnt be too sure but it prob should fit straight on Quote Link to comment Share on other sites More sharing options...
karlos1987 Posted February 6, 2014 Author Share Posted February 6, 2014 As far as i am aware for the front bumper you will have to get the grilles and fog mounts but the bumper itself will fit straight on, as for the rear i wouldnt be too sure but it prob should fit straight on Ok thanks for that. I did think myself that it should be a direct replacement just wanted to check. Thanks. Sent from my C5303 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 7, 2014 Share Posted February 7, 2014 I do believe that the ST fog lights have different mounting brackets so a set of lenses and brackets may be needed from Ford. The upper grille is also slightly smaller i think. The rear bumper will be a direct swap, all brackets and wiring connectors will be the same. Quote Link to comment Share on other sites More sharing options...
karlos1987 Posted February 7, 2014 Author Share Posted February 7, 2014 I do believe that the ST fog lights have different mounting brackets so a set of lenses and brackets may be needed from Ford. The upper grille is also slightly smaller i think. The rear bumper will be a direct swap, all brackets and wiring connectors will be the same. Ok thanks for your help. Will look into the front bumper. Ford focus mk2.5 1.6 titanium. Quote Link to comment Share on other sites More sharing options...
