toxic Posted May 3, 2009 Share Posted May 3, 2009 hello how would you add neons in a ford fiesta finesse 04 model thanks Quote Link to comment Share on other sites More sharing options...
Ronnie Roberts Posted May 3, 2009 Share Posted May 3, 2009 just fit a switch thru bulkhead into dash... wire it in same way you would a sub and amp... Clip them under front and rear bumpers and try and locate somewhere to fit them in the side.... Wiring is easy its the getting the neons clipped on in place thats a B1t£$ Quote Link to comment Share on other sites More sharing options...
toxic Posted May 5, 2009 Author Share Posted May 5, 2009 just fit a switch thru bulkhead into dash... wire it in same way you would a sub and amp...Clip them under front and rear bumpers and try and locate somewhere to fit them in the side.... Wiring is easy its the getting the neons clipped on in place thats a B1t£$ o rite..how would i wire it so that when i open the door dey come on? Quote Link to comment Share on other sites More sharing options...
greenymk7 Posted May 5, 2009 Share Posted May 5, 2009 wire them into your door switches or your internal light as it works off the same switch Quote Link to comment Share on other sites More sharing options...
Ronnie Roberts Posted May 5, 2009 Share Posted May 5, 2009 pretty much as above... be warned if u wire them into door switch u will only get them when that door is opened! if u want them with all doors u would have to run it from the light itself.. more hassle but better idea!! why do u want them when the doors are open? sureley u would want them on when the doors are shut? switch on the dash is defo the easiest but i geuss it depends on what ur after! Quote Link to comment Share on other sites More sharing options...
toxic Posted May 6, 2009 Author Share Posted May 6, 2009 orite thankss peoplee Quote Link to comment Share on other sites More sharing options...
