Renegadeshania Posted March 8, 2014 Share Posted March 8, 2014 Hi All Ive got the dreaded Flashing Glow Plug Light coming on if i boot it past 3000rpm in 3rd gear. If the car is warmed up i can just turn it off and the light goes off until i go over 3000 in 3rd I have bought a Ford Super F MK 2 Fault Code Scannerand put it on the obd ii port the car is a 2005 euro 4 2.0 tdci Mondeo . I read the DTC and it comes up with P1000 ODB systems readiness test not complete P132BFINEDDTC The Live Data is as follows The Second pic is after the Glow plug light is flashing the EGRp reads 0 and doesnt change. Any Help greatly appreciated thanks Steve :) Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted March 8, 2014 Share Posted March 8, 2014 Sounds like the egr valve might need a clear out! Sent from my MY SAGA C2 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
BigD Posted March 9, 2014 Share Posted March 9, 2014 That error code means the turbo vanes/actuator are stuck. The turbo either needs replacing, or completely stripping and cleaning. I don't recommend replacing it, as there's nothing wrong with the turbo that a good clean won't fix, and it'll only happen again over time anyway even with a new turbo. Plus, cleaning it is much cheaper. I had a mechanic mate sort mine - took him most of the day and he charged me £200. So I'd expect a repair bill of at least that amount. Keep your RPM under 2k until you've got it sorted, otherwise you'll bust the actuator. Oh, by the way - you can ignore the P1000 code as it isn't a fault code as such. You'll see it quite often. Not 100% sure exactly what it does mean, but the bottom line is there's nothing wrong if that's the only code you've got. 1 Quote Link to comment Share on other sites More sharing options...
Renegadeshania Posted March 20, 2014 Author Share Posted March 20, 2014 Thanks for that BigD im going to drop the cat and do the mr muscle trick when it gets a little warmer :D Quote Link to comment Share on other sites More sharing options...
