Invisible Man Posted March 19, 2014 Share Posted March 19, 2014 Hi, Does anyone know of a way I can stop the Air Conditioning kicking into life when I put the heaters on in my car? I think the A/c is in need of some attention as when it turns on you can hear a very loud noise that sounds like dodgy bearings (Does the Air Con system have any bearings?) I thought about removing a fuse, but when I looked at the fuses there are quite a few that relate to the A/C/heating System. Cheers Gary Quote Link to comment Share on other sites More sharing options...
alexp999 Posted March 19, 2014 Share Posted March 19, 2014 Make sure the blowers are not pointing at the windscreen, this enables the A/C automatically. Quote Link to comment Share on other sites More sharing options...
Invisible Man Posted March 19, 2014 Author Share Posted March 19, 2014 That makes sense. I always point them at the windscreen when I turn the car off so I dont get a freezing blast of cold air to the face when I start it up. Sent from my GT-I9505 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
BigD Posted March 19, 2014 Share Posted March 19, 2014 The noise is probably just the standard noise from the A/C compressor. They aren't the quietest devices on the planet. Make sure to run the A/C at least once every couple of weeks, even in winter. The a/c coolant contains lubricant and if you don't run it for a period of time, the seals will dry out and the a/c system will leak. Just watch this forum when the first hot weather arrives - I guarantee at least a couple of posts a week asking why the A/C is no longer working. This is why. Quote Link to comment Share on other sites More sharing options...
Invisible Man Posted March 19, 2014 Author Share Posted March 19, 2014 Is there a noticable difference with the Ford A/c units compared to other manufacturers? I had a Vauxhall prior to this and you couldn't really hear it. I'll make sure I run it every now and again to keep it happy. Cheers Sent from my GT-I9505 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
BigD Posted March 19, 2014 Share Posted March 19, 2014 I had a Vauxhall prior to this and you couldn't really hear it.It was probably broken. :P (sorry, couldn't help myself) 1 Quote Link to comment Share on other sites More sharing options...
Invisible Man Posted March 19, 2014 Author Share Posted March 19, 2014 It was probably broken. :P (sorry, couldn't help myself) Hahahahaha. Probably was mate.....there is a reason I didn't buy another Vauxhall and went for a focus Sent from my GT-I9505 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
