philg84 Posted March 21, 2014 Share Posted March 21, 2014 Hi All Took my car for a major service and cam belt change at my local ford dealer. half way home heard a horrible whining noise from the engine and the steering got heavier and heavier. got home and popped the bonnet and there was red oil splattered everywhere and leaking on the ground. Im guessing the power steering pump has gone. I rang them as soon as I got home and they said they will pick it up in the morning. As it was fine before taking it to the garage, am I right in assuming they will repair it for free? any help will be appreciated. Phil Quote Link to comment Share on other sites More sharing options...
stef123 Posted March 21, 2014 Share Posted March 21, 2014 I'm afraid this is quite a common fault on the mk2 1.6 I doubt they will pay for it unless they have had any reason to interfere with it at the service Quote Link to comment Share on other sites More sharing options...
wase16ll Posted March 21, 2014 Share Posted March 21, 2014 to do the timing belt, they probably disconnected the pump reservoir and swung it to one side, or removed it..if the leak is from the low pressure hose/connections then may have a case, but think these models had a common issue with the pas high pressure pipe to pump seals which may possibly been disturbed but doubt you'll get any comeback for it.. Quote Link to comment Share on other sites More sharing options...
