happyben Posted March 22, 2014 Share Posted March 22, 2014 Hey guys, noobie alert.... I have a problem with the reverse lights not working on my 08 Mondeo. I did a search and found the common fault with the gearbox switch so purchased a new one (from ebay) and swapped it this morning.....still not working :-( I have checked the bulbs and all of the fuses I can find and they're all good. Any body got any further ideas?? Thanks Ben Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted March 22, 2014 Share Posted March 22, 2014 If you replaced the gearbox switch, is it actually putting out any voltage on the circuit? Quote Link to comment Share on other sites More sharing options...
happyben Posted March 24, 2014 Author Share Posted March 24, 2014 I dont have a tester to check at the moment. I will see if I can borrow one to check..... Does anyone have a wiring diagram that I can use to follow through. ....the car has a towbar fitted and want to check that this isnt causing an issue too... Sent from my GT-I9505 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
