vinzchau9 Posted March 22, 2014 Share Posted March 22, 2014 Hi I've been experiencing abs and traction control lights coming on intermittently with a juddering sensation when I apply the brakes. I think this is down to the ABS reluctor ring which may need changing, however could anyone tell me where I can source a replacement ring for the front hubs? I've been searching online but come across rings for the rear only. Thanks Quote Link to comment Share on other sites More sharing options...
stef123 Posted March 22, 2014 Share Posted March 22, 2014 Someone will correct me if I'm wrong but... I have only changed non abs front wheel bearings on the old mk1 before but I believe models fitted with abs use different wheel bearings. Quote Link to comment Share on other sites More sharing options...
vinzchau9 Posted March 23, 2014 Author Share Posted March 23, 2014 Thanks, yea I've just checked and realized its part of the wheel bearing assembly. Would anyone have any idea what could be causing the abs and traction lights to flick on intermittently? As well as that i'm experiencing a vibration like noise when I go over a hump or rough patch of road and sometimes a juddering sensation when I apply the brakes. Could it be the wheel bearings or abs sensors? Thanks Quote Link to comment Share on other sites More sharing options...
