AdamC11 Posted March 24, 2014 Share Posted March 24, 2014 Hi Guys, I was after some information. On a Fiesta MK7 Edge, what is the rear brake/drum set up on that car? Cheers Ads Quote Link to comment Share on other sites More sharing options...
Mike77 Posted March 24, 2014 Share Posted March 24, 2014 How do you mean ? Quote Link to comment Share on other sites More sharing options...
AdamC11 Posted March 24, 2014 Author Share Posted March 24, 2014 I mean, are they brakes or drums? Cheers Quote Link to comment Share on other sites More sharing options...
iNath Posted March 24, 2014 Share Posted March 24, 2014 All Fiesta's have drums apart from the MK7 ST. Quote Link to comment Share on other sites More sharing options...
AdamC11 Posted March 24, 2014 Author Share Posted March 24, 2014 Cheers iNath, Is there anything in the drum help the car brake or not? Cheers Quote Link to comment Share on other sites More sharing options...
alexandjen Posted March 24, 2014 Share Posted March 24, 2014 Cheers iNath, Is there anything in the drum help the car brake or not? Cheers Yes, brake shoes that push against the drum to slow the car down and hold the car stationary when the hand brake is applied Quote Link to comment Share on other sites More sharing options...
AdamC11 Posted March 24, 2014 Author Share Posted March 24, 2014 Cheers alexandjen. When do the brake shoes need replacing? Cheers Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted March 24, 2014 Share Posted March 24, 2014 Id say normally around 30-40,000 miles they dont wear that much tbh as its 70/30 braking so the fronts do all the work really, my car has done 38,000 and the rear shoes in the drums are still in good condition Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
AdamC11 Posted March 24, 2014 Author Share Posted March 24, 2014 The reason im asking. I had new pads and discs fiited and when i brake it sounds like its metal touching metal. Any ideas? Cheers Quote Link to comment Share on other sites More sharing options...
D13 HPD 95 Posted March 24, 2014 Share Posted March 24, 2014 You get that with new pads and discs until the pads are worn in 100miles should be enough with general braking, also the outside of the pads should have had a little copper slip applied to them to top them being squeaky (on the outer side not the acc pad) If you still think its the shoes jack the rears up take the wheels of and the drum lid comes of with two bolts and you can see the shoes and how much meat they have left and if there is more than around 4-6mm id say your fine m8 and make sure its got even wear too, and no major dents or marks on the inner lip on the lid then its fine Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
AdamC11 Posted March 24, 2014 Author Share Posted March 24, 2014 I have easily done over a 100 miles. So im not sure now. Haha. Cheers Quote Link to comment Share on other sites More sharing options...
Nighthawk Posted March 24, 2014 Share Posted March 24, 2014 How have you been braking? Whilst bedding in its best to brake carefully or you may end up with uneven wear or warped discs. Sent from my HUAWEI Ascend P2 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
AdamC11 Posted March 24, 2014 Author Share Posted March 24, 2014 Thanks for all the replies. I have been braking normally. Ford are picking it up on Wednesday. will have to wait and see what they say. Cheers Quote Link to comment Share on other sites More sharing options...
Nighthawk Posted March 24, 2014 Share Posted March 24, 2014 Good luck, hope its nothing or they sort it with little to no cost. Let us know how you get on. Sent from my HUAWEI Ascend P2 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
AdamC11 Posted March 24, 2014 Author Share Posted March 24, 2014 Will do. Is there a possibility they could have moved or not been fitted right? Cheers Quote Link to comment Share on other sites More sharing options...
AdamC11 Posted March 26, 2014 Author Share Posted March 26, 2014 Hi Guys, Car has been into ford today. The guy has had all the wheels off and says he couldn't find anything. It quite possible it could have been brake dust. P.S. No charge Quote Link to comment Share on other sites More sharing options...
Nighthawk Posted March 26, 2014 Share Posted March 26, 2014 I take it they cleaned them and the noise has gone now? Sent from my HUAWEI Ascend P2 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
