smiler Posted March 25, 2014 Share Posted March 25, 2014 Hi, i have a zetec 2006 and when i put the car in reverse instead of my usual beeping tone ,i am getting a long tone for 3 seconds.i have read other forums and it states there is a problem with one or all the sensors ,has anyone had this issue . regards Quote Link to comment Share on other sites More sharing options...
wase16ll Posted March 25, 2014 Share Posted March 25, 2014 would agree most likely culprit is a faulty sensor Quote Link to comment Share on other sites More sharing options...
mick85 Posted March 26, 2014 Share Posted March 26, 2014 If u stick ur ear up to each sensor individual u can usually hear same noise this give u an indication Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
137699 Posted March 28, 2014 Share Posted March 28, 2014 Look to see if the paint is bubbling on any of the sensors. And many owners get this issue when it rains - see if it clears up in the dry. Quote Link to comment Share on other sites More sharing options...
747777 Posted March 29, 2014 Share Posted March 29, 2014 Check for harness/wiring integrity in the rear. Quote Link to comment Share on other sites More sharing options...
Richieski Posted July 18, 2014 Share Posted July 18, 2014 I had this, plugged in diagnostic. it told me it was the front NS inner sensor. So i swapped it with the inner offside sensor and the diag still told me it was on NS inner. So we know the sensor is good. This left me with the wiring. I physically started to check cable and connectors from the sensor and found a broken cable where it ran behind the lower front grille. Can't quite remember but on the drivers front wing from the engine bay i removed the headlight and under that is a multi connector with all the front sensors going to it. I used a continuity tester to test the each cable individually from this connector to the sensor. You do need to have a diagnostic to tell you which sensor is the problem, i used the ELM327 device. Quote Link to comment Share on other sites More sharing options...
mickk47 Posted March 3, 2015 Share Posted March 3, 2015 I have the same problem, only since my battery was disconnected, so do I disconnect my battery again to see if this will work Quote Link to comment Share on other sites More sharing options...
gregers Posted March 3, 2015 Share Posted March 3, 2015 worth a try? make sure you know your code to the stereo. Quote Link to comment Share on other sites More sharing options...
Exdecuk Posted March 17, 2015 Share Posted March 17, 2015 Its quite often the looms front / rear. Not expensive & easy to replace Quote Link to comment Share on other sites More sharing options...
