marklord1983 Posted March 26, 2014 Share Posted March 26, 2014 Howdo guys quick question, im gonna get my timing and aux belt done soon and need to know if the water pump is driven by the timing belt? It's a focus 2007 2.0 tdci cheers chaps Sent from my SM-N9005 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
sambo87 Posted March 26, 2014 Share Posted March 26, 2014 I know the water pump is on the aux belt on the 1.8 tdci engine but I got told by ford that they recommend changing the cambelt either at 125000 or 10 years which ever comes sooner so I would ring them to check cheers Sam Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
marklord1983 Posted March 26, 2014 Author Share Posted March 26, 2014 Mines same interval time but then you hear of a few failing before this i've been quoted 95 for all the bits including water pump then 120 for labour, or I might just wait till 115000 miles but im starting to worry Sent from my SM-N9005 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
sambo87 Posted March 26, 2014 Share Posted March 26, 2014 Something else always seems to break on mine every time it's got to go into the garage :-( Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
marklord1983 Posted March 26, 2014 Author Share Posted March 26, 2014 Touch wood mines been ok other than a few bits i've been quoted 230 all in for timing belt water pump and aux belt which isn't bad at all Sent from my SM-N9005 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
marklord1983 Posted April 10, 2014 Author Share Posted April 10, 2014 Just an update guys, I had timing belt aux belt tensioners water pump and gear Box oil changed and it cos me 270 altogether which I fantastic I think. Sent from my SM-N9005 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 19, 2014 Share Posted April 19, 2014 that is one heck of a cracking deal! Quote Link to comment Share on other sites More sharing options...
marklord1983 Posted April 19, 2014 Author Share Posted April 19, 2014 I know couldn't believe it myself Sent from my SM-N9005 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
goomba Posted July 11, 2014 Share Posted July 11, 2014 Wen changing the belts and stuff. What shud b changed on a mk 2.5 1.8 tdci? Sent from my GT-I9505 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 11, 2014 Share Posted July 11, 2014 Timing belt, aux belt and their pulleys are a minimum Quote Link to comment Share on other sites More sharing options...
goomba Posted July 11, 2014 Share Posted July 11, 2014 Somebody mentioned idle tensioners. Dont have the faintest idea if dat needs to b replaced too Sent from my GT-I9505 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 11, 2014 Share Posted July 11, 2014 anything the timing belt touches ideally would be replaced. As that makes sure everything is replaced and done and less likely to fail! Quote Link to comment Share on other sites More sharing options...
