Help Wiring Radio/cd In 2010 Ka
RnB Rookie
Hi all,
I need some help wiring my Kenwood KDC BT73DAB.
I have managed to get it working, but its permantly live, so I have to remember to switch off head unit, each time I leave the car.
(see pics)....
Connector 2 has 4 wires:
Black: earth
Red/Green: constant 12v+
White: ????
Blue: ???
What are the Blue and White for?
what are the Grey, Black and Green wires for on Connector 1 for? Connector 1 is currently NOT connected.
thanks in advance,
Kev.C.
post-52679-0-45523700-1396202038_thumb.j
post-52679-0-10766800-1396202039_thumb.j
post-52679-0-02279900-1396202040_thumb.j
Con 2 could be steering wheel controls do you have a multi meter or 12v tester see what is the memory and ignition and could be a antena remote etc
Sent from my GT-I9305 using Ford OC mobile app
Hi Matt,
thanks for your reply.
I've found that Connects2 do a full harness adaptor kit for this, so fingers crossed it will be sorted next weekend :)
Cool no worries I think iv used them or there saposed to be good lol
  • 9 years later...
Hi I’m having the same issue with my ford did the connect2 adapter work if so what one did you use? Did you use con1 or just con2 ?
  • 5 weeks later...
I had the same issue when i was wiring my sony dsx-a410bt. I could not find a stable 12v switched power on the car iso harness. I ran a cable from the fuzebox underneath the steering column using one of these fusebox adapters. (use a multimeter to find a switched 12v one)
You want to run this to the 12v switched power on your headunit. (i just pulled out the pin and connected the wire to this) In my case it had to go to the red cable on the headunit adapter. (it could also be blue).
The small iso wiring plug i also have disconnected, i think its for the aux plug.
My ka doesn't have steering wheel controls tho.
