How To Lock The Doors From Inside?
 Share
Hi again, daft question maybe...but can the doors all be locked from inside? If so, how? Mk3 LX version!
Not that Im paranoid or anything, but without the door lock knobs I cant see how to do it unless I use the key fobs?
Cheers
Link to comment
Are you on about the MK 3 Focus or are you on about a Mondeo ??
If its the Mk3 Focus then the button to lock the doors is just below the radio controls ,looks like a open padlock symbol.
Link to comment
Isn't there a lock/unlock switch on the door with the electric window switches?
Sent from my HUAWEI Ascend P2 using Ford OC mobile app
Will have to look, but from memory there seems to be a 'lock window' button, if Im right, which doesnt seem to lock the windows anyway!! Will check and update in the daylight
Link to comment
Yeh Mk3 Mondy
Link to comment
is this while your driving as the mondeo have a auto lock if you drive over 5 - 10 mph they auto lock
Motion Auto-lock –MONDEO MK3
Turn on the ignition so the dashboard lights are illuminated. DO NOT start the engine.
Lock the door using the button on the door handle
Then unlock the door (but do not open it) three times.
Turn OFF the ignition.
Turn on the ignition but don’t start the engine - you will hear a distinctive beep.
Lock the door again as before then unlock it (only once this time) - a final beep will be heard.
Your
doors will now auto lock when you pull away. This will also auto lock
the doors in reverse. If you need to disable this feature, then repeat
the steps above.
Link to comment
Doh, sorted! It was a little button/lever above the door opening handle! Didnt see it until this post suggested I look! So thanks everyone for the inputs!!
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
