How To: Change Date And Time ?
Rather annoying at the moment.
I've been through every setting possible and can't find any way to adjust the time on the dash or radio ?
the radio is the Navigation one and the dash has both square display that shows full time and date when not using the nav and rectangle screen below for trip computer
i found the settings for steering etc. but time settings are not there.
been through the navi setting everywhere and cant find it on the radio either.
is it even possible to change the time ?
cheers !
I dont know about that particular one but on most its the menu button on the stereo then scroll to date and time and press now you can adjust the time
the radio isint that kind,
its the ford Denso touchscreen sat nav radio !
On mine it's on the menu by using the stalk. And it's listed as clock on the dash.
Not being 'au-fait' with this particular model I'm just throwing this suggestion in :) Is it possible that it could update the time etc automatically when it recieves a signal via the radio? I only say this because both my clock radio alarm and my Roberts DAB radio updated themselves today. The Roberts only did it after the radio had been on for a little while though.
cheers for the replies lads,
i went through all the "stalk" settings, i.e steering, units, etc and wasn't there sadly :/
i was thinking it might update itself via radio, dunno if it will or not as im still waiting but i'll try many different stations to see how it goes !
still not changed.
any ideas anyone ?
if its any help car has cruise control on steering wheel too ?
Sent from my GT-I9505 using Ford OC mobile app
The Denso has the ability to obtain the time from the GPS signal. Using the satnav for some time should be enough to automatically set the date/time. it should also be possible to manually set the date/time. To do this you can simply press on the date/time which is shown on the Denso screen. This should open the date/time menu.
From what I know on some firmware versions of the Denso setting the date/time can be a problem. A common problem is that the radio will not accept changing the date/time. In this case you could try to open the satnav screen on the Denso first. Next you can press the date/time at the top left of the screen to access the date/time menu. Now you should be able to change the date/time.
  • 5 years later...
Found by fluke.
Click on clock setting. It says up down options to change the time.
Before you press anything to change the time, press left when the hour flashes, it'll take you to the year so you can change the date.
16 hours ago, Princess81 said:
Found by fluke.
Phew, that was a real cliff hanger that! Been waiting 6 years for the answer... 🤣
