dexterboyz Posted April 3, 2014 Share Posted April 3, 2014 like the title says I have a code 13 on my immobiliser, does anyone know how I sort this properly without bypassing the immobiliser? many thank. Quote Link to comment Share on other sites More sharing options...
mick85 Posted April 3, 2014 Share Posted April 3, 2014 What is ur car Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
dexterboyz Posted April 3, 2014 Author Share Posted April 3, 2014 fiesta 35 van, 2001 mk4 or 5 i'm not quite sure. many thanks. Quote Link to comment Share on other sites More sharing options...
mick85 Posted April 3, 2014 Share Posted April 3, 2014 Non-PATS key or damaged encoded ignition key, or no key code received. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
dexterboyz Posted April 3, 2014 Author Share Posted April 3, 2014 have already tried swapping the immobiliser ring with no luck😬! what would the next step be to sort it out properly? I read that the ecu can be swapped with the corresponding key used? or can an auto tech sort this out? many thanks. Quote Link to comment Share on other sites More sharing options...
mick85 Posted April 3, 2014 Share Posted April 3, 2014 Did u try spare key or programming key again Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
dexterboyz Posted April 3, 2014 Author Share Posted April 3, 2014 all I have is one black key? many thanks. Quote Link to comment Share on other sites More sharing options...
mick85 Posted April 3, 2014 Share Posted April 3, 2014 Has it got a blue or red chip in it u would first have try reprogram key or get new key that first step Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
dexterboyz Posted April 3, 2014 Author Share Posted April 3, 2014 it has a red cover on the chip? who would I go to for reprogramming? many thanks. Quote Link to comment Share on other sites More sharing options...
mick85 Posted April 3, 2014 Share Posted April 3, 2014 Ford or maybe a specialist could do it google it an ring round try get best price Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
dexterboyz Posted April 3, 2014 Author Share Posted April 3, 2014 cheers, will give it a go, however is there a way of doing it by changing the ecu over? many thanks. Quote Link to comment Share on other sites More sharing options...
mick85 Posted April 3, 2014 Share Posted April 3, 2014 You could but u have change ignition barrel to suit key a lot more hassle buyin ecu an barrel den fitting them be easier bite bullet an buy new key an try get both them programmed together cause there is a chance ur key is broke an wont program so new key best way go Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
