Mk1 1.8 Cold Start Issue
.Steve
Morning all
New here so bare with me!
I'm trying to work out what is going on with a family members Focus 1.8, it appears to have developed a problem with cold starting (even in the recent warm weather). It takes around 5 seconds of cranking before it will start, it tries to catch while cranking but doesn't and all of a sudden it'll fire and run ok. Idle seems to settle down to normal cold levels right after.
If you then shut it off after a few seconds and then attempt to start again, it starts first time.
Not sure what could be going on? I don't know the last time it was serviced so I'm thinking it could probably benefit from an oil and spark plug change, but is what I am describing typical of other faults? I've been reading the ICV/PCV can cause some strange problems?
Hope somebody will be able to help
Cheers!
Tried starting it from stone cold with a little bit of pressure on the throttle... fired up no problem. Stuck IACV?
I would of thought if ICV there would be other symptoms such as uneven idle? Is it only the cold start issue you are experiencing?
Sent from my HUAWEI Ascend P2 using Ford OC mobile app
Hi mate
No other problems seem to be showing themselves, the idle seems OK.
