Boosh Posted April 15, 2014 Share Posted April 15, 2014 Hi all, my cruise control used to work fine, then suddenly stopped working. I don't get the 'cruise control on stand-by' message anymore, and pressing the + or - button afterwards doesn't make any difference.. I previously had the same problem, but sorted it out by holding down 'on' and' set' buttons' . But that doesn't seem lo make any difference, this time. I'm not suspecting a faulty (brake or clutch ) switch, as the cruise control doesn't even get on stand-by. It's all the more annoying that I'll be selling the car, soon. I read about a button test on the focus that makes all buttons ping as you press on them. Does such a test exist on the mk4? Or any pointer to enable cruise control? Thanks, M. Quote Link to comment Share on other sites More sharing options...
mick85 Posted April 15, 2014 Share Posted April 15, 2014 Year an model Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Boosh Posted April 15, 2014 Author Share Posted April 15, 2014 Sorry, it's a mk4 1.8 tdci zetec (2008). Thanks. Quote Link to comment Share on other sites More sharing options...
mick85 Posted April 15, 2014 Share Posted April 15, 2014 So wat have u checked so far Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Boosh Posted April 15, 2014 Author Share Posted April 15, 2014 I've tried all combinations of buttons held down simultaneously, but to no avail. I've also tried disconnecting the battery for 20mn. All it achieved was having to reset the clock and the one-touch-up windows. Any idea? Boosh. Quote Link to comment Share on other sites More sharing options...
mick85 Posted April 15, 2014 Share Posted April 15, 2014 Have had it checked for fault codes most common issue brake or clutch switch did u test these yet Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Boosh Posted April 15, 2014 Author Share Posted April 15, 2014 I do not have access to a code reader. Perhaps naively I ruled out the pedal switches, as my problem is the cruise control not coming to standby, not actually activating. In any case, how would I go about testing said switches? Would I need b multimeter? I think it's likely to be a simple fix, but members' experience is needed on that one... Boosh. Quote Link to comment Share on other sites More sharing options...
ralph Posted April 16, 2014 Share Posted April 16, 2014 Hi I have the same car with same problem! (Recently posted on this myself Here)..I've looked it up on the net and apparently its down to bad electrical connections in the switches. According to most the only way to cure it is either clean connections or replace switches which involves removal of steering wheel and airbag etc etc. I didn't fancy all that hassle so I looked down the sides of the switches and could see 4 very small square holes. These holes are just big enough to get the end of a small straw down so I sprayed down each one with contact/switch cleaner. This I did a week ago and normal operation was resumed instantly and has worked fine ever since at all speeds... Worth a try for a 5-minute fix! Sent from my iPhone using Ford OC 1 Quote Link to comment Share on other sites More sharing options...
Boosh Posted April 16, 2014 Author Share Posted April 16, 2014 Thanks, I'll give it a go. Not sure I've got contact cleaner, would WD** do the job? In any case, thanks for your help, I thought it'd be a silly thing. Forum's only as good as its members contribution... Boosh. Quote Link to comment Share on other sites More sharing options...
ralph Posted April 16, 2014 Share Posted April 16, 2014 No mate its not at all like wd40... This stuff I have is called "pro-power contact cleaner".... If you google it its available for £3-4 a can. It's designed to clean up and enhance "electrical conductivity and contacts"... Basically it's used to clean up dirty/poor contacts in hifi and amplification equipment... Though I don't want to shout too soon since I squirted it into those holes the cruise has come back and has not gone wrong since. That was two weeks ago and I do find myself checking it all the time out of paranoia! If you do decide to replace there's a set on eBay at the moment item 29112151005 and run out in 14 hrs from now... Current price £5.50!!! Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Boosh Posted April 16, 2014 Author Share Posted April 16, 2014 Thanks for all the info, will give it a go and report back. Boosh Quote Link to comment Share on other sites More sharing options...
ralph Posted April 16, 2014 Share Posted April 16, 2014 Good luck with it and let me know! BTW I found the best way to do it was to first start the engine then squirt the contact cleaner into the holes in the side whilst simultaneously pressing the cruise stand by switch repeatedly until it started working. On a different note... I don't know the spec of your mondeo, but did you know if you haven't got footwell lights the wiring and bulb holders are probably there ready! My 1.8 TDCI Zetec didn't have them but all it took were a couple of 5w capless bulbs at 13p each and hey presto... Instant upgrade!!! Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Mpdunn Posted February 8, 2019 Share Posted February 8, 2019 My cruise control don’t come on, all I get is the message Cruise Control Stability? Any ideas? Quote Link to comment Share on other sites More sharing options...
Data43 Posted August 30, 2019 Share Posted August 30, 2019 My cruise control not working it’s fault code is u0405 I’ve got ford ids program it networks to the car but carnt find the ccm module so I tried adding the module but no joy any ideas Quote Link to comment Share on other sites More sharing options...
TinaW Posted June 30, 2020 Share Posted June 30, 2020 On 4/16/2014 at 11:45 PM, Boosh said: Thanks for all the info, will give it a go and report back. Boosh How did it go? Did it work? 🙂 Quote Link to comment Share on other sites More sharing options...
N. Druce Posted July 12, 2021 Share Posted July 12, 2021 Had the same problem with my Mondeo cruise control, tried the blowing air into the 4 small holes on the switch, working fine again now. Problem solved, glad I read this link. Thanks Quote Link to comment Share on other sites More sharing options...
Grandric Posted July 16, 2021 Share Posted July 16, 2021 Hi had this, it worked for a bit but the problem came back. There was a DTC (can't remember the code) which I cleared and haven't had the problem since Quote Link to comment Share on other sites More sharing options...
