matt1981 Posted April 22, 2014 Share Posted April 22, 2014 Had my Ecoboost since Sat, loving it. Haven't pushed it hard yet apart from a handful of gear changes, I love it when the turbo kicks in and pushes you into the seat (you can tell my last car for 8 years was a 61bhp!). Being my first turbo charged engine I was wondering what the lifespan is of an average turbo? Is it a costly fix if/when it does pack up? I was hoping to keep this car 8 years give or take like my previous car, to get my money's worth out of it. Sent from my GT-I9100 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
BigRog Posted April 22, 2014 Share Posted April 22, 2014 I wouldn't worry for the the first 3 years Matt, it's under warrenty. I should imagine a new one should be in the region of £1200 fitted at todays prices, more for bigger ones. Just let the engine idle for a minute or two after a run to enable the oil flowing through the turbo to cool, it will prolong it's life. It will start to whistle when it's on it's way out. Quote Link to comment Share on other sites More sharing options...
matt1981 Posted April 22, 2014 Author Share Posted April 22, 2014 Will do, thanks Roger. All of us new focus/fiesta owners are like Guinea pigs with this new engine really Sent from my GT-I9100 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
SandyCat Posted April 22, 2014 Share Posted April 22, 2014 It's also important to make sure the engine has clean oil. For turbo engines I recommend a 6 monthly oil and filter change but yearly at least. This keeps the small oil holes clear. Dirty oil blocks them and result in early turbo failure. With proper care a turbo can last well over 100,000 miles although it depends on their state of tune as to how long they are designed to last. Quote Link to comment Share on other sites More sharing options...
FOCA Posted April 22, 2014 Share Posted April 22, 2014 Will do, thanks Roger. All of us new focus/fiesta owners are like Guinea pigs with this new engine really Sent from my GT-I9100 using Ford OC mobile app Not really, before the engine design was released to the public it was run for 100,000s of miles in different conditions, real and simulated As others have said, frequent oil/ filter changes (with the right/ quality oil/ filter) will help protect the engine/ turbo sensibly running the engine in/ always warming the engine up before "booting" it helps lonngevity but, "pottering about" and labouring the engine is bad too, and a good "italion tune up" now and again is a good thing After a hard run, the oil is hot and it stays hot for a long time, letting the engine idle for a few minites (without revving the engine) is to allow the turbo to stop spinning, as well as to allow the oil to cool a little, it is when engine is switched off if the turbo is still hot and spinning that problems can occur, as this turns off the oil feed to the turbo bearing as well - some cars were fitted with "turbo timers" that keep the engine running a few minites after the ignition key is removed (dont think they are road leagal, though) another solution is an electric oil pump (that continues to run after the engine is switched off) Its not so much a problem with modern turbos as it was with older ones 1 Quote Link to comment Share on other sites More sharing options...
matt1981 Posted April 22, 2014 Author Share Posted April 22, 2014 Interesting stuff, thanks all Quote Link to comment Share on other sites More sharing options...
