jd_james Posted April 26, 2014 Share Posted April 26, 2014 Wondering how easy this is to do for someone not so technical with cars? If it's easy enough can someone give me some advice in what is needed to be done. Cars rolling back when clicked up one or two and never used to. Sent from my GT-I9505 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 28, 2014 Share Posted April 28, 2014 is it disks on the rear? If so, there should be an adjustment screw somewhere around the centre hub, it should be a case of handbrake off, car chocked, and a few flicks of the wrist with a screwdriver on either side. This will then tighten the handbrake for you, but make sure you do equal tightening on both sides to ensure a non bias breaking. Quote Link to comment Share on other sites More sharing options...
jd_james Posted April 28, 2014 Author Share Posted April 28, 2014 Yeah disks on the rear cool ill give this a go! Sent from my GT-I9505 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
alexp999 Posted April 28, 2014 Share Posted April 28, 2014 I thought it was only the ST which had rear discs on the Fiesta? 1 Quote Link to comment Share on other sites More sharing options...
jd_james Posted April 28, 2014 Author Share Posted April 28, 2014 sorry drums on the rear * Typo from the mobile! Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 28, 2014 Share Posted April 28, 2014 ah OK, in which case its a different process, I think you have to get under the car and with the handbrake down and get at the adjustment nut on the underside rear of the drum, then tighten this up, or at least I believe thats the case with the modern drums? Quote Link to comment Share on other sites More sharing options...
E5GDM Posted April 28, 2014 Share Posted April 28, 2014 Your cars too new to have to be messing around with the brakes yourself, take it back to the dealer & let them sort it our. 1 Quote Link to comment Share on other sites More sharing options...
jd_james Posted April 28, 2014 Author Share Posted April 28, 2014 Think I'm being too anal about it i tried my mates n mine was tight compared to his.. Don't flip that sentence into something dirty :p Sent from my GT-I9505 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
iNath Posted April 28, 2014 Share Posted April 28, 2014 Don't flip that sentence into something dirty :P You managed that all by yourself! Quote Link to comment Share on other sites More sharing options...
jd_james Posted April 28, 2014 Author Share Posted April 28, 2014 I realised. Just couldn't be arsed to rewrite I'm too tired Sent from my GT-I9505 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted April 29, 2014 Share Posted April 29, 2014 lol, yeah you definately managed that without any help Quote Link to comment Share on other sites More sharing options...
pumahsf Posted May 13, 2014 Share Posted May 13, 2014 Remove the drum (with a good hit with a hammer) You will see an adjuster at the top just below the wheel cylinders on that there is a ring which if you look you will see only turns one way, Use a flat screwdriver to turn that ring a couple of turns until when you put the drum back on and spin it, it will stop within 5 seconds, reeat on the other side. Also a good idea to take a bit of emory paper and clean up rhe shoes and remove any lip from the drum Sent from my GT-I9505 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
