Big-tom Posted April 28, 2014 Share Posted April 28, 2014 I'm looking to decat my car is there any way of avoiding the engine management light coming on? Thanks tom Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
FOCA Posted April 29, 2014 Share Posted April 29, 2014 Decatting a modern petrol - engined car is like opening abig can of worms - strictly speaking, it shoukld have a cat (catalytic converter) present, without the cat, the emmissions may be high and it may be very difficult to get it through the MOT, the lambda seneor is tied into the ECU and fuel- air ratio, it can often mes these things up If it is more performance you are after, you would be far better off getting the car remapped (a Bluefin takes the car from 225 to 270Hp approx much more than decatting- and the car stays legal) If you already have a remap and/or want to make more noise, (+ a bit more power) get rid of the back- box, many manufacturers make "sports" systems/ the back-box may be more restrictive than the cat, once you have the remap, back-box dellete and high-flow exhaust, then you should consider a high-flow cat instead of a decat, on a petrol- engined road car Note that what applies to a petrol engine with an active cat (with a lambda sensor) noes not apply to a diesel engine with a passive cat (from a technical viewpoint as well as the MOT emmisions test, as only the particulates are measured on a diesel MOT emmisions test)- so if you read someting about decatting a diesel, it may not apply to a petrol- engined car, or vice-versa Quote Link to comment Share on other sites More sharing options...
