Gpallett Posted April 29, 2014 Share Posted April 29, 2014 What engines would my MK4 Ford Fiesta Quote Link to comment Share on other sites More sharing options...
MattDRX Posted April 30, 2014 Share Posted April 30, 2014 If you have the 1.25 Zetec, a good option is the 1.7 Puma lump, quite a popular thing to do and goes well, no loom mods needed iirc Quote Link to comment Share on other sites More sharing options...
Gpallett Posted April 30, 2014 Author Share Posted April 30, 2014 I was hoping to lean more towards a 2.0L 170 focus engine so I don't have to tune it as much Sent from my C5303 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
MattDRX Posted April 30, 2014 Share Posted April 30, 2014 Puma 1.7 engine is very quick in a fiesta, look up some YT vids you have a look, I cant see a little Fezza taking that lump and gear box, plus you'll need custom drive shafts so it all fits in and they will be around £600 plus. Quote Link to comment Share on other sites More sharing options...
Gpallett Posted April 30, 2014 Author Share Posted April 30, 2014 Would you how much would it cost for a puma conversion + turbo Quote Link to comment Share on other sites More sharing options...
MattDRX Posted April 30, 2014 Share Posted April 30, 2014 A huge amount of money, essentially you'd need the engine and gear from a Ford racing Puma, they only made 500 of them and a rotten one goes for about 4k. Another thing to maybe look at would be a mk3 Fiesta RS Turbo set up ( or just buy the car ) it should fit straight in I can't see Ford changing much in terms of mounting points and given the car is pretty much the same it shouldn't be too difficult. Engines and gear for them are quite cheap and very easy to work on. Sent from my SM-N9005 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
btmaldon Posted April 30, 2014 Share Posted April 30, 2014 I would go for the 1.7 Puma engine. It was quick in the Puma and should be quicker in the Fez. Like Matt says, it should more or less drop straight in. Quote Link to comment Share on other sites More sharing options...
MattDRX Posted April 30, 2014 Share Posted April 30, 2014 It does go straight in but the original.car needs to be the zetec as you'll need a loom mod ( loads of money ) to make it run. Sent from my SM-N9005 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
