Invisible Man Posted May 2, 2014 Share Posted May 2, 2014 Hi, I'm lookin at buying some new led sigelights http://www.ebay.co.uk/itm/2x-CREE-W5W-T10-501-LED-wedge-car-bulbs-SIDE-LIGHT-INTERIOR-WHITE-6000K-HID-LEDs-/161273413175?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item258ca4fe37 But they are 15mm wide......does anyone know if these will fit?? Cheers Quote Link to comment Share on other sites More sharing options...
salsheikh Posted May 2, 2014 Share Posted May 2, 2014 they are 501's so should be astraight fit. check out the guides on the forum for more info Quote Link to comment Share on other sites More sharing options...
Lenny Posted May 2, 2014 Share Posted May 2, 2014 Hi, I'm lookin at buying some new led sigelights http://www.ebay.co.uk/itm/2x-CREE-W5W-T10-501-LED-wedge-car-bulbs-SIDE-LIGHT-INTERIOR-WHITE-6000K-HID-LEDs-/161273413175?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item258ca4fe37 But they are 15mm wide......does anyone know if these will fit?? Cheers doesnt say if these bulbs are Canbus compatable mate, They need to be canbus compatable in order to work Quote Link to comment Share on other sites More sharing options...
Invisible Man Posted May 2, 2014 Author Share Posted May 2, 2014 Canbus?? Not all that great with electrics, what does that mean? Cheers Quote Link to comment Share on other sites More sharing options...
btmaldon Posted May 2, 2014 Share Posted May 2, 2014 I doubt they would go through the hole. The LED's I fitted were snug and they weren't as wide as those. Quote Link to comment Share on other sites More sharing options...
btmaldon Posted May 2, 2014 Share Posted May 2, 2014 In simple terms (simple for my benefit not yours) LED lights have such a low power drain the cars system will think the bulb has blown and you will have a warning light on the dash permanently. The Canbus error bulbs fix this. Quote Link to comment Share on other sites More sharing options...
Lenny Posted May 2, 2014 Share Posted May 2, 2014 Canbus?? Not all that great with electrics, what does that mean? Cheers modern cars operate on whats called the Can-Bus system, Its a form of electronic pulse technoligy, Basiclly when upgrading bulbs to led type you must be sure the led's your buying are CanBus error free bulbs, This applies to the rear reg plate and front parking position bulbs, Quote Link to comment Share on other sites More sharing options...
Invisible Man Posted May 2, 2014 Author Share Posted May 2, 2014 Hmmmm. Might give them a whirl and return them if they don't fit/work. Cheers Quote Link to comment Share on other sites More sharing options...
btmaldon Posted May 2, 2014 Share Posted May 2, 2014 Rear number plate bulbs don't need to be canbus error free on the Mk2.5. Dont know about the Mk2 though. I put non error free ones on and they were fine. I dont think it is linked to the can-bus system Quote Link to comment Share on other sites More sharing options...
JW1982 Posted May 2, 2014 Share Posted May 2, 2014 The Focus MK2/MK2.5 does have a CANbus system (in fact there are 2 CANbus systems) but this system does not check the lights. Every 12 Volt LED bulb can be used on the Focus MK2/MK2.5. There is no need to buy expensive CANbus LED's. The only position where non CANbus LED's do not work are the front and rear indicators but this has nothing to do with the CANbus system. The indicators are controlled by an electronic blinking relay which is integrated into the GEM module fuse box. The type of this blinking relay is based on the power consumption of the indicator bulbs. LED's have a much lower power consumption than a conventional light bulb. This results in fast blinking indicators. This problem can be solved by adding resistors or using CANbus LED's which have the same power consumtion as conventional light bulbs. Quote Link to comment Share on other sites More sharing options...
footfistart Posted May 2, 2014 Share Posted May 2, 2014 I'm also looking into upgrading to leds. On the off chance I took one of my headlight bulbs out to see if anything came up and nothing came up. So I can only imagine I've haven't got canbus either for lights. My car is only a zetec on a 60plate Quote Link to comment Share on other sites More sharing options...
btmaldon Posted May 2, 2014 Share Posted May 2, 2014 So all of us bozzoes that put error free LED's in to replace the side light bulbs were wasting our time and money. Oh well :( Quote Link to comment Share on other sites More sharing options...
Invisible Man Posted May 2, 2014 Author Share Posted May 2, 2014 So....I went and got the same lights from a local shop. They worked, no errors on the dash....but didn't fit in the sidelight hole...... I believe I now have the brightest footwear lights in history though Sent from my GT-I9505 using Ford OC mobile app 2 1 Quote Link to comment Share on other sites More sharing options...
