Help With Boot Mechanism....
Hi all,
Well after buying my Focus MK2 2005 in Feb I've encountered what i believe to be my first issue....
If my memory serves me right when I pressed the key fob to unlock the car this used to unlock all the doors and also the boot - however now it seems the boot doesn't unlock with the doors
The boots does however unlock when I press the boot button on the fob.....
Any ideas?
Focus MK2 2005, GHIA
All perfectly normal.
The boot unlocks with the key button or opens with the button between the numberplate lights when the car is unlocked.
Sent from my SM-G900F
Hi, thanks for the reply - I didn't explain too well sorry - when i unlock the doors with the fob and try and open the boot using the handle between the number plate light nothing happens - I'll then have to press the boot button on the fob to make it 'pop' open... I therefore assume this isn't normal?
It could be that water has got into the boot switch. These can be replaced but you can probably take the thing out, clean it up and dry it out and get it operating again.
I get where you're coming from now.
The boot switch does have a habit of corroding and gumming up.
Gain access to the switch by removing the hatch liner and undoing the bolts holding the trim in place so you can have a good look at the switch mechanism and wiring.
New switches are not expensive and are reasonably straightforward to replace, it may just need a good clean and spraying with contact cleaner/WD40.
again...cheers or the replies guys.
I'll hope for some nice weather this weekend so i can get to it and have a look see if i can't fix it with some WD40
Is there a long term solution/anything i can do to protect the part?
