mactell Posted May 22, 2014 Share Posted May 22, 2014 Hi all, As owners of an MK6 know when you unlock the car the side lights and interior light comes on... How can I hook it up so they headlights come on as well? Quote Link to comment Share on other sites More sharing options...
Samiieeyy Posted May 22, 2014 Share Posted May 22, 2014 Not sure how you do that but I do have a question for you if you don't mind ... Have you put lights In your foot wells? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
mactell Posted May 22, 2014 Author Share Posted May 22, 2014 Not sure how you do that but I do have a question for you if you don't mind ... Have you put lights In your foot wells? Sent from my iPhone using Ford OC Yes I have... :) Quote Link to comment Share on other sites More sharing options...
Samiieeyy Posted May 22, 2014 Share Posted May 22, 2014 What did you use and how are you powering l. I know you can get a strip like thing and have it plugged into the cigarette lighter but I don't like the sound of that it will be on show?? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
mactell Posted May 22, 2014 Author Share Posted May 22, 2014 Erm I didn't do it myself. However it is wired to the ignition so will only come on when the key is turned to the ignition or engine is on. Then is also linked up to a switch so I can still have the lights off even if the engine is off. Then in the both the footwells are blue LED strips from eBay. I also used to have a white LED strip in the front Grill. Quote Link to comment Share on other sites More sharing options...
MattDRX Posted May 22, 2014 Share Posted May 22, 2014 You can bridge it off the live feed for the radio. Quote Link to comment Share on other sites More sharing options...
Samiieeyy Posted May 22, 2014 Share Posted May 22, 2014 Erm I didn't do it myself. However it is wired to the ignition so will only come on when the key is turned to the ignition or engine is on. Then is also linked up to a switch so I can still have the lights off even if the engine is off. Then in the both the footwells are blue LED strips from Ebay. I also used to have a white LED strip in the front Grill. Ok thanks I will have a look :) Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Samiieeyy Posted May 22, 2014 Share Posted May 22, 2014 You can bridge it off the live feed for the radio. Is that for the lights in the foot well? That sounds much easier! :) Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
mactell Posted May 22, 2014 Author Share Posted May 22, 2014 Is that for the lights in the foot well? That sounds much easier! :) Sent from my iPhone using Ford OC Take a look at this guide... It might help you. http://www.fordownersclub.com/forums/topic/44777-fitting-leds-in-the-footwell-handbrake-example-on-a-mk65/ Quote Link to comment Share on other sites More sharing options...
MattDRX Posted May 22, 2014 Share Posted May 22, 2014 Yes, all it needs is a live and negative feed, the loom to the radio has these so can be bridges, just make sure you take the proper live and NOT the 12V battery back up that keeps the clock / timers going etc as they will be permanently on, this is usually the Yellow and Green wire but it has been red on other cars I've seen, such as VX that have them the other way round. Quote Link to comment Share on other sites More sharing options...
Samiieeyy Posted May 22, 2014 Share Posted May 22, 2014 Thanks guys :) Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
mactell Posted May 27, 2014 Author Share Posted May 27, 2014 BUMP?? Quote Link to comment Share on other sites More sharing options...
