Dielectric Grease - Advice
I have used dielectric grease on my leads and plugs when i changed them a while back, and i wanted to know if i applied the stuff correctly.
Initially i covered the electrical connectors with a bit of grease and put some on the spark plugs where the ignition boot clips on, but now after seeing on youtube a video on how to correctly use dielectric properly i am not sure if i used it right.
Should i only put some on the porcelain on the plugs and the rubber around the ignition lead or should i coat the metal connector inside the leads.
