Little Trip Computer
After having an ABS sensor changed myTrip Computer has started reading Backwards in the mode that gives distance availability i.e. the more fuel I use the further I can go, What could be the problem??
Solved by seaeaacr
Possibly just reset - it takes a while to settle down
To be honest, I tend to use the odometer to guesstimate range per tank based on previous fill ups
How recently was the ABS sensor changed?
Sent from my SM-P600 using Ford OC mobile app
  • Solution
The ABS sensor was changed, oh 6 weeks ago
Another topic Where the H*** is the A/C charging point on a Focus
On a Mk2/2.5 one cap is behind the offside headlight, the other is further back on the same side.
Thanks a lot, but not too easy to find are they?
