Flushing Oil
HI-GUYS, I am thinking of doing a oil and filter change on my mk6 1.4 petrol engine soon, will I need to flush the engine or is there no need to flush. my handbook says to use 5w30 engine oil only.
Solved by L666JER
  • Solution
I wouldn't flush an old engine, having a bit of crap in there can help stop leaks etc.
I think it's far better to do regular oil changes with top quality oil.
thanks james, will do the oil change only
I'm with James 100%. There should be no need to flush unless you have reason to do so. Just use a quality oil and change it regularly
thanks for your advice guys
Best on on this? how can you do that. there is no info in that answer what so ever.......... give it to one of the members who have advised you .. that is what it is there for...... fool
What???
he has scored his own reply as the best answer from the topic...
