peterparker5081 Posted June 7, 2014 Share Posted June 7, 2014 hi all just looking for a bit of advice as i dont seam to be able to find the answers anywhere else so im in the process of buy a mk3 focus i have looked at a few but am angling towards a white auto etc or titanium i wanted the sony stereo as my Gf has it in her new fiesta zetec and it does the job well BUT i also wanted a sat nav and the only focus i can find for sale with the sony sat nav are pushing £18k for a zetec? :D :D :D :D :D soooo i was thinking if i bought the sat nav seperate will it just plug and play is it a simple click in and out job? has anyone done this so far because if it need wiring, or the fitting needs to be modded in anyway? will the sync still work like blue tooth etc? and the unit i was gonna get is from the US if that makes any difference? thanx in advance guys :D Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 7, 2014 Share Posted June 7, 2014 Sadly you cant have both parts. You either have to have the satnav unit or a seperate unit like a tom tom. I do not believe there is anyway you could do it otherwise. Quote Link to comment Share on other sites More sharing options...
peterparker5081 Posted June 7, 2014 Author Share Posted June 7, 2014 Sadly you cant have both parts. You either have to have the satnav unit or a seperate unit like a tom tom. I do not believe there is anyway you could do it otherwise. both? im asking if i can swith them over or will there be a lot more too it? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 8, 2014 Share Posted June 8, 2014 swapping a headunit isnt too bad, but I dont think there is one with all you want in it. Quote Link to comment Share on other sites More sharing options...
Rossbclarke123 Posted June 8, 2014 Share Posted June 8, 2014 Are you saying here you just want to put a Sony Nav unit in it+ Sent from my HTC One_M8 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
peterparker5081 Posted June 8, 2014 Author Share Posted June 8, 2014 Are you saying here you just want to put a Sony Nav unit in it+ Sent from my HTC One_M8 using Ford OC mobile app yes, i wanted to know if its a direct replacement job? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 8, 2014 Share Posted June 8, 2014 You would likely need additional wiring for the GPS I suspect, and you may also need a stalk adapter to get the controls, but otherwise it should be a swap? Quote Link to comment Share on other sites More sharing options...
