Spraying Rear Diffuser And Front Grills
Hi Everyone!
I'm thinking of spraying my rear diffuser and front grills but I am not sure whether gloss black or satin would look best and if people have tried it them selfs what sand paper and stuff they used?
Any help would be appreciated!
Here's the way i done some
Wash all the parts
600 grit wet and dry
Wash and grease remover
3 coats of primer
Leave 24 hours
Wet and dry 1200 grit any high spots
Wash and grease remover again
3 - 5 coasts of top coat i like gloss black better than satin
Leave 24 hours
Very very light 2000 grit dry paper
3 coast of lacquer thin layers only
Then leave 24hours
Then buff with a polish wax and fit them :)
Cheers mate, will have to give it ago maybe next week!
You have a good feed on your fezzy btw, really nice job :)
Thanks man :)
This is mine done in gloss black.
Used the exact same method as above.
Sent from my C5303 using Ford OC mobile app
Looks a lot better in gloss black!
You've done a good job on that mate as well!
Cheers. Was the first mod I done. Hate the way they come. Just look dull. Well worth the time to do them imo
Yeah, it doesn't do any of the fords justice when they are in the dull grey
The only bad thing is with this it's very time consuming and I don't really have much time :/
To be honest when.I done my wing mirror covers I was pushed for time so I just allowed 30 mins drying time between each coat. I never left them for 24 hours between the primer, gloss and laquer. However if you do it this way you won't be able to sand them down as above because you would end up pulling the paint off.
Yeah I will, just have to do it all over a weekend sometime, might as well do it properly rather than having to do it again!
With my wing mirrors I done the following.
Took off the car
Wet and dry sand
Washed off with soapy solution
Dried properly.
Primer 3 coats. Half hour drying between coats
Gloss black 3 coats. Again half hour drying.
Laquer 2-3 coats.
Pic isn't the best for looking at wing mirrors but it is a perfect finish.
You might get the very odd rough feel in places where your not sanding it between coats.
Took a few hours. But like you say it's much better to do it properly. Then you will get a pristine finish.
To be honest your mirrors look like a proper job anyway so I might try a shorten the job down like you
